It needs so time to realize, that the carousel.*-dc has no effect, but has to exist regardless. I changed now the max_vel and max_acc to get proper speed.
Next issue is to figure out, how to drive the carousel to pocket-1-position after/within the init-sequence.
I'am sorry - I didn't attach my lastest config files. They're added now.Does it need to? It should home itself the first time that it is enabled. Though I don't see any connection to the "sense-0" pin (home sensor) in your HAL file.
The carousel component has jogging built in. Just connect buttons (physical or software) to the carousel.0.jog-plus and jog-minus pins.
And another issue I think about: After correct homing I obviously do not need the step-calculation in M11 and M12...I just have to jog n times where n is the amount of pockets to move. Is this correct? As I'am not a software developer: How can I code a carousel jog in the M12 ngc file?
So cool image missing /media/kunena/emoticons/w00t.png Thanks a lot. I'll try that an be back.Would a home-offset pin help? I have added one.
