Mesa 7i92 Dolt not cleared
4 years 4 months ago #245535 by DoWerna
Replied by DoWerna on topic Mesa 7i92 Dolt not cleared
$ lscpu
Architecture:        x86_64
CPU op-mode(s):      32-bit, 64-bit
Byte Order:          Little Endian
Address sizes:       36 bits physical, 48 bits virtual
CPU(s):              4
On-line CPU(s) list: 0-3
Thread(s) per core:  1
Core(s) per socket:  4
Socket(s):           1
NUMA node(s):        1
Vendor ID:           GenuineIntel
CPU family:          6
Model:               42
Model name:          Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
Stepping:            7
CPU MHz:             1596.286
CPU max MHz:         3700.0000
CPU min MHz:         1600.0000
BogoMIPS:            6584.73
Virtualization:      VT-x
L1d cache:           32K
L1i cache:           32K
L2 cache:            256K
L3 cache:            6144K
NUMA node0 CPU(s):   0-3
4 years 4 months ago - 4 years 4 months ago #245536 by PCW
Replied by PCW on topic Mesa 7i92 Dolt not cleared
OK so the timings look OK
Does your system have a Intel Ethernet chip?
What are your ping times if you ping the 7I92?
Last edit: 4 years 4 months ago by PCW.
4 years 4 months ago #245580 by DoWerna
ping timings
ping 192.168.1.121
PING 192.168.1.121 (192.168.1.121) 56(84) bytes of data.
64 bytes from 192.168.1.121: icmp_seq=1 ttl=64 time=0.392 ms
64 bytes from 192.168.1.121: icmp_seq=2 ttl=64 time=0.240 ms
64 bytes from 192.168.1.121: icmp_seq=3 ttl=64 time=0.165 ms
64 bytes from 192.168.1.121: icmp_seq=4 ttl=64 time=0.221 ms
64 bytes from 192.168.1.121: icmp_seq=5 ttl=64 time=0.139 ms
64 bytes from 192.168.1.121: icmp_seq=6 ttl=64 time=0.226 ms
64 bytes from 192.168.1.121: icmp_seq=7 ttl=64 time=0.166 ms
64 bytes from 192.168.1.121: icmp_seq=8 ttl=64 time=0.120 ms
64 bytes from 192.168.1.121: icmp_seq=9 ttl=64 time=0.175 ms
64 bytes from 192.168.1.121: icmp_seq=10 ttl=64 time=0.281 ms
64 bytes from 192.168.1.121: icmp_seq=11 ttl=64 time=0.360 ms
64 bytes from 192.168.1.121: icmp_seq=12 ttl=64 time=0.116 ms
64 bytes from 192.168.1.121: icmp_seq=13 ttl=64 time=0.321 ms
64 bytes from 192.168.1.121: icmp_seq=14 ttl=64 time=0.385 ms
64 bytes from 192.168.1.121: icmp_seq=15 ttl=64 time=0.280 ms
64 bytes from 192.168.1.121: icmp_seq=16 ttl=64 time=0.289 ms
64 bytes from 192.168.1.121: icmp_seq=17 ttl=64 time=0.324 ms
64 bytes from 192.168.1.121: icmp_seq=18 ttl=64 time=0.336 ms
Is there a terminal command with which I can display my network chip?
4 years 4 months ago #245593 by PCW
Those ping times look pretty bad...
You might try:
dmesg | grep -i eth
4 years 4 months ago #245599 by DoWerna
looks like i have the Intel chip :-(
4 years 4 months ago - 4 years 4 months ago #245601 by PCW
OK for Intel Ethernet chips, you must disable RX IRQ coalescing
This is typically done in the interfaces file
man hm2_eth
for instructions
Also you can try this temporary fix:
sudo ethtool -C eno1 rx-usecs 0
and then try the ping test / LinuxCNC again
(this fix will only last until you reboot)
The following user(s) said Thank You: DoWerna
Moderators: PCW, jmelson
Time to create page: 0.398 seconds
