Mesa 7i96S MPG encoder on P1
1 year 3 months ago #332014 by roland100
Hello PCW,
A few days ago i flashed my 7i96s with the 7i96sd_inmp1v2.bin file. Flashing was without error.
Since then, the X-axis-homing does not work anymore.
Homing of y-axis and z-axis works fine, as expected.
I would be glad to get your help to solve this issue
Is there a way to get the 7i96s in the state before flashing ?
Tanks a lot
1 year 3 months ago #332017 by roland100
Hello PCW,
I found a solution:
I flashed my 7i96s with the 7i96sd_mpgp1.bi file from the mesa homepage. Now everything works as expected.
My goal is to wire my MPG to P1, I think, this bin-file is for realizing this too.
Thanks a lot
1 year 3 months ago - 1 year 3 months ago #332023 by PCW
Replied by PCW on topic Mesa 7i96S MPG encoder on P1
Yeah, sorry about that, made a quick change in the V2 version, and had a typo
that broke 7I96 input 0
EDIT:
Note that the 7i96sd_mpgp1 firmware has a different pinout on P1 and not a close match
to the common wired MPGs. I just fixed and re-uploaded the 7i96sd_inmp1v2 firmware
if that's more appropriate (and the  7i96sd_inmp1v1 firmware was always OK )
Last edit: 1 year 3 months ago by PCW.
1 year 3 months ago #332491 by roland100
Hello PCW,
I hope to get some help from you again.
I tried to make a custom bit file consisting of these two files 7i96s_2pwmd and 7i96sd_mpgp1. 7i96s2pwmd for pwmgen (Stepgen 4-) and 7i96sd_mpgp1 for mpg on P1.
I used the enfinity software, but it doesn't work because of a version conflict.
Do you know which efinty version works with the 7i96s firmware from the homepage ? Thanks a lot
1 year 3 months ago #332493 by PCW
It should work with any version, I have used from 2021.2 to 2024.something
1 year 3 months ago #332526 by roland100
I tried efinity 2025.1.When I try to open the project seveni96s.xml i get the error:
The previous synthesis run has failed. To avoid potential problems or unreliable data, please run it again.
I click O then I get the message:
The family or device maybe invalid. Click OK to proceed with default family and device. Click Cancel to close project and abort.
Then I click OK the next message:
Encounter internal error. Please get help from support team
What does this all mean ? Do I have to choose a family or device first ?
I`m working on xubuntu 24.04
Do you have any suggestions ?
Moderators: PCW, jmelson
Time to create page: 0.407 seconds
