PFM to control spindle speed?
- OliverLSedlacek
30 Dec 2022 12:18 #260542
by OliverLSedlacek
PFM to control spindle speed? was created by OliverLSedlacek
I've acquired a Denford Novamill which is a part complete 'convert to linuxCNC' project. It's come with a SpindleV3 PCB to convert a parallel port signal into the 0V to10V that the spindle speed controller expects. My problem is that the interface board expects PFM, zero to 2000 Hz pulses, but the StepConv wizard only offers PWM or PDM. Can I get LinuxCNC to produce PFM for spindle speed control?
- Thank you received: 5334
30 Dec 2022 14:30 #260545
Replied by PCW on topic PFM to control spindle speed?
Yes, you could use either a stepgen (in velocity mode) or the siggen component to generate the PFM
The Stepgen has the advantage that its frequency command scaling is adjustable
so the commanded RPM => frequency translation is done just by setting one parameter.
- OliverLSedlacek
31 Dec 2022 11:42 #260631
by OliverLSedlacek
Replied by OliverLSedlacek on topic PFM to control spindle speed?
Great, how do I do this though?
31 Dec 2022 17:28 - 31 Dec 2022 17:29 #260665
Basically you edit your hal file to add the additional stepgen (set to velocity mode)
then set the scaling and width parameters for that stepgen and finally "net"
LinuxCNC spindle speed command pin to the spindle stepgens velocity command input
(and possibly net LinuxCNCs spindle on command to the stepgen enable pin)
(man stepgen)
If you post your current hal/ini files, I can make some examples of the changes needed
(man stepgen)
Last edit: 31 Dec 2022 17:29 by PCW.
- OliverLSedlacek
01 Jan 2023 16:35 #260711
by OliverLSedlacek
That's brilliant, just the sort of guidance I need. I'll have a crack at it myself to start with.
- OliverLSedlacek
03 Jan 2023 12:03 #260836
by OliverLSedlacek
It's taking me a while to get my head around the 969 pages of documentation, so I'd like to take you up on the offer of editing my hal/ini files (attached).
03 Jan 2023 17:17 #260853
First step would be to add the new stepgen
To do that you would change
loadrt stepgen step_type=0,0,0
to
loadrt stepgen step_type=0,0,0,0 ctrl_type = p,p,p,v
(man stepgen)
to
(man stepgen)
- OliverLSedlacek
07 Jan 2023 11:22 - 07 Jan 2023 11:47 #261159
by OliverLSedlacek
This isn't going well. I put the following lines in the HAL:
net spindle-cmd-rpm => stepgen.3.velocity-cmd
net spindle-on <= spindle.0.on => stepgen.3.enable
net spindle-pfm <= stepgen.3.step
setp stepgen.3.maxvel 5000.0
setp stepgen.3.position-scale 0.4
setp stepgen.3.steplen 230000
setp stepgen.3.stepspace 230000
LinuxCNC terminated immediately with errors below:
Invalid parameter 'ctrl_type'
Follow up edit, after staring at the code for ages I clock the extraeneous space characters either side of the =. I've left the post up for other newbies like me.
Last edit: 07 Jan 2023 11:47 by OliverLSedlacek. Reason: Found my own solution
07 Jan 2023 16:12 #261176
Sorry for the spaces in the example, the command line parser is quite picky...
- OliverLSedlacek
07 Jan 2023 16:46 #261179
by OliverLSedlacek
I get that, if a space is a separator then it's a separator. As a veteran C/C++ coder I just don't 'see' spaces.
Time to create page: 0.149 seconds
