Retrofit Mesa Options
3 years 5 months ago #272489 by Rios
Retrofit Mesa Options was created by Rios
Hello, I'm thinking of retrofitting an old punching machine, the machine only has 2 axis (X,Y) and the punching mechanism is manual but i'm thinking on making it semi auto/auto , my only experience with linuxcnc was on a retrofit using a complete ethercat solution , from servo drives to beckhoff ethercat i/o , so , in this project that solution is not very cost-effective , I'm trying to use most of the machine material , is this case is :
-2 Heidenhain 500pp encoder for feedback
-2 siemens ac motor's controlled by an analog Simodrive
In my research my first option would be a pc with a mesa 5I25 PCI card and a 7I77 card , the 7I77 card is capable of everything that I need for motion/feedback with a extra of i/o , does this option make sensor, or I'm missing something with this setup ? Recommendation or advice will are accepted .
The other question is , if I wanted to remove the PCI 5I25 for an Ethernet solution for "easy" exchange with other pc's , would the Mesa 7I92TH be a okay solution ? On the website, it says that it's compatible with the 7I77 card , but would the 7I92TH be a okay replacement for the 5I25 card ?
i'm sorry for any wrong/stupid assumption that i  may be making in this post, but my knowledge on this topic is limited and recent , thanks for any feedback .
3 years 5 months ago #272492 by tommylight
Replied by tommylight on topic Retrofit Mesa Options
5i25 is PCI, 6i25 is PCI-E, 7i92 is ETH, they are the same functionaly.
Finding those is quite hard lately, still, see if you can find 7i97 as that is both 7i92 and 7i77 in one place/board, easier wiring.
If you can not find 7i97 or 7i92, you may find 7i96S for a bit more money and with 7i77 you end up with all of the above plus 5 step/dirs and another spindle/encoder. And more IO.
3 years 5 months ago #272493 by Rios
Replied by Rios on topic Retrofit Mesa Options
Thanks , that is a great advice , i will try to see what i can get my hand on .
3 years 4 months ago #273519 by my1987toyota
Replied by my1987toyota on topic Retrofit Mesa Options
from Mesa the 7i92TF and 7i77 are in stock
7i77
7i92TF
3 years 6 days ago #283853 by Rios
Thanks for all the help.
This project was on standby by the client, and now I have the green light, but the old options are out of stock.
My ideia for controlling the 2 analog servo motors and the read 2 encoder are the following:
7I80HDT Ethernet Anything I/O card
7I36 Quad Analog Servo Interface
Would this work for my situation? Any better option in the situation in question? Thanks for all the feedback.
3 years 6 days ago #283865 by tommylight
7i96S
7i85 or 7i85S
7i83
should be in stock, can do stepgens and analog and seems like the best combo for now.
Moderators: PCW, jmelson
Time to create page: 0.205 seconds
