BOB wiring
3 years 3 months ago #275402 by Stef
Replied by Stef on topic BOB wiring
I am using a PNP normally open limit switch. The voltage between sensor pins 3 and 4 (measured on the BOB screw terminals) is 9.4V when the sensor is not activated, and 23.4V when the sensor is activated.
Sensor pin 1 is wired to the +24V from the power supply.
Sensor pin 3 is wired to GND of the BOB (so it is directly connected to the GND that is used for the 5V Mesa power supply, the 5V / 24V BOB power supplies and the 48V stepper motor power supply).
Sensor pin 4 is wired to BOB pin 12.
3 years 3 months ago #275419 by PCW
Replied by PCW on topic BOB wiring
The BOB inputs expect a connection to ground to operate
(so a NPN sensor)
3 years 3 months ago #275430 by Stef
Aha I see, yes then that will be the mistake, thank you for the help!
Most CNC/automation webshops in my area have much more choice in PNP sensors than NPN, so I thought PNP was more standard.
I am wondering whether I need a normally open or normally closed switch (there is no manual available for the BOB).
2 years 9 months ago #291565 by OttoOrange
Replied by OttoOrange on topic BOB wiring
Another Newbie here.
I have the same BOB and you’re right … documentation doesn’t exist. My question is whether you know what the white 4 pin male connectors grouped above the X Y Z A and B connections might be for. The pins on my BOB are labelled as +5v CLK CW and NE which I believe is a typo for EN.
My stepper drivers are DRV8835 and do not seem to need to be configured for + or - step or dir. The common cathode or anode configuration?
My BOB is a DAOKI DC 12-24v CNC BOB 5 axis Mach 3. Optoisolators on the 5 input pins so I guess I need to provide at least 12v to get them to work.
OO
2 years 3 months ago #306179 by geostein8888
Replied by geostein8888 on topic BOB wiring
Hello,
these white connectors are to nonnect the steppers via such cables who fit in
by the way, did you got the endswitches/ref switches to work? i have now the second board and the signal is not coming through to linuxcnc, i have connected the 12V
do i need to use the GNDon the input pin blocks for the sensors somehow instead of the gnd i use for the step/dir signals?
Georg
Moderators: PCW, jmelson
Time to create page: 0.288 seconds
