Mesa 7i96s 5v supply reverse polarity damage
3 years 1 month ago #279880 by CarterKraft
How do I keep the wifi working while connected to the Mesa card?
3 years 1 month ago - 3 years 1 month ago #279882 by PCW
If you disconnect/reconnect the card this will typically update the interface settings to the latest
(the ifup/ifdown scripts run)
Not sure why you have a WIFI issue unless you are using wicd
(instead of network manager). Wicd is broken if multiple interfaces
are present
Last edit: 3 years 1 month ago by PCW.
3 years 1 month ago #279886 by CarterKraft
I am using NetworkManager Applet v1.30.0
Is there any other boxes to check in the setup for the Mesa Ethernet or should it just work?
3 years 1 month ago #279892 by CarterKraft
I clicked the use this connection only for this network in the routes and that seemed to work now.
Thanks for the help! Getting closer all the time.
Moderators: PCW, jmelson
Time to create page: 0.079 seconds
