6i24-16
- Nitram
- Thank you received: 15
I apologize, because I suspect you get asked this question about a million times, but I wonder if you could give an idea of when the 6i24-16 may be available again.
Thanks,
Marty.
- Thank you received: 5334
that require redesign ahead of it however
- Nitram
I am currently using a 5i24. Have a backup pc just in case, but it has no PCI connection, rather only PCIe.
So just to confirm two things for the time some 6i24's become available:
1. From an FPGA flash perspective, simply flash the exact same bit file onto the 6i24 as the 5i24 is currently using? and
2. From a HAL file perspective, no other changes are necessary other than changing any reference from 5i24 to 6i24?
Is that about it?
Thanks!
- JT
- Thank you received: 595
JT
- ErrickW
- Thank you received: 8
as some Spartan 6 chips have become available again. At the minimum we are attempting to have a
at least physically equivalent replacement for most cards going forward.
- Nitram
Its hard to predict what will be available in the current conditions, but we will likely build 6I24-16s soon as some Spartan 6 chips have become available again
Just wondering if any updates on the 6i24 as yet?
Thanks.
- Nitram
Just looking for an update please.
Are the 6i24-16 getting closer?
Many thanks.
Marty.
- Nitram
