thank you meister ,
That's exactly the idea, but how is it configured?
Can you direct me to some specific document?
If you use pncconf to create the original hal/ini files, a PID loop will already be setup for each joint.
Changing the joint feedback source and tuning parameters are needed for encoder feedback.
(along with getting the encoder feedback in the correct direction and scaled properly)
Tuning can be done live using the calibrate menu.
_BUT_ as others have mentioned, simple adding encoders to a step/dir system will not solve a
missed step issue (though it can halt the system if this occurs) This is because when a missed
step occurs, the drive had insufficient torque and skipped one or more pole positions (1/50th of a turn)
Having the controller simply add more steps will not fix this (and least not without slowing the motion
significantly so the torque becomes higher)
