How can I use the 48 I/O ports on the 7i76?
2 years 7 months ago - 2 years 7 months ago #295611 by kofsky0328
I use db25 to connect 7i95 and 7i76D. I configured the following information in the hal file: net flood-output iocontrol.0.coolant-flood => hm2_7i95.0.7i76.0.2.output-00, but starting linuxcnc shows that hm2_7i95.0.7i76.0.2.output-00 is not found.
Attached is the firmware and pinout I use
Last edit: 2 years 7 months ago by kofsky0328.
2 years 7 months ago #295612 by PCW
Looks like the 7I76 field I/O is on channel 1 with that firmware
so the names would be like:
hm2_7i95.0.7i76.0.1.output-00
2 years 7 months ago #295614 by kofsky0328
The problem remains, it still shows that hm2_7i95.0.7i76.0.1.output-00 does not exist.
The attachment is the halcmd show pin file
2 years 7 months ago #295615 by kofsky0328
Is it possible that the problem is with the db25 cable?
2 years 7 months ago - 2 years 7 months ago #295616 by PCW
Does the 7I76D have both field and 5V power?
(7I76D W2 Left, 7I95 W23 UP for 5V from 7I95)
The connecting cable should be flat a cable with
standard IDC  (crimp-on) connectors
Last edit: 2 years 7 months ago by PCW.
2 years 7 months ago #295618 by kofsky0328
Yes, 7I76D W2 Left, 7I95 W23 UP, cr1 and cr2 led lights are all on.
Moderators: PCW, jmelson
