Mesa 7i96S SSERIAL and pktuart
2 years 6 months ago #298164 by PCW
Replied by PCW on topic Mesa 7i96S SSERIAL and pktuart
It's probably:
addf mesa_ifm.00 servo-thread
If in doubt about function names, run linuxcnc with a working
configuration with the desired components loaded and then
run this command (in a terminal):
halcmd show funct
The following user(s) said Thank You: lkavan
2 years 6 months ago #298225 by lkavan
Great! addf mesa_ifm.00 servo-thread was the solution! Now, HAL started and I have a data on RS485 Now, I am going to modify modbus driver to IFM bus - there are different opcodes and different checksum. It is the protocol of www.sabo.de I hope, this should not be so big problem.
But please, you have written about "known mesa-modbus bug" What are they? Will be better to know about them when there will be any problem with communication...
Thanx a lot for your help!
2 years 6 months ago #299014 by lkavan
Thanx a lot again, it works finally! I have improved mesa-modbus to IFM bus and machine running ;-)
2 years 6 months ago #299034 by PCW
Glad that it worked for you.
Moderators: PCW, jmelson
Time to create page: 0.258 seconds
