Any other driver board choice except mesa board?
2 years 6 months ago #298956 by timaer
Got it .Thanks a lot!
2 years 6 months ago #298999 by OttoDidact
I went to that page and they seem to also manufacture or are related to an affordable and attractive sounding controller. Expatria Technologies Flexi-HAL
FlexiHAL Isolated CNC Controller for GRBLHAL and LinuxCNC
expatria.myshopify.com/en-us/products/flexi-hal
I might be interested in this one myself. When I upgrade my router table. I'm using a C&CNC Bob that they stopped manufacturing years ago.
2 years 6 months ago #299000 by OttoDidact
I searched GRBLHAL which I learned about from the FlexiHAL page. Seems like GRBL has come a long way and there is much more capability there than there used to be.
Not LinuxCNC, but might get you where you are going.
www.grbl.org/breakboards
The following user(s) said Thank You: timaer
2 years 6 months ago #299040 by timaer
Yes ,GRBL is famous ,but not very suitable for my situation .I 'll develop a mathine with both lathe and 4 axis milling ,so GRBL board not completely satisfied
2 years 6 months ago #299379 by timaer
Hi,I've read a few material about EtherCAT,and our boss of company also decided to use EtherCAT as the solution of building the cnc machine.But the linuxcnc seems not so much support to EtherCAT ,at least not offering the PncConf and StepConf wizard such like GUI panel and not very much turial about ethercat on the official document .The most useful thing I found is in the form EtherCAT section about the installation of the EtherCAT .so if I choose to use EtherCat to build the machine ,the biggest problem is I dont have many document or related material connecting with Linuxcnc,after all ,I need to use it to control the machine. Do you have any advice for a newbee,I'll appreciate it very much .
2 years 6 months ago #299381 by tommylight
From your questions and replies, you should get an old PC with a parallel port and some drives/motors, install LinuxCNC and make that work, whatever that is.
Jumping into EtherCAT is OK if you are willing to persist and read a lot, the same goes for any hardware machine control.
I am sure you can get it working with the help of very good members on this forum, just follow directions and advice you get from them.
But if you expect wizards to do everything for you, just don't start. Wizards are just to give you a something to work with, they do everything for simple normal machines/controllers, but they can not do everything for thousands of hardware combinations out there.
Editing hal files is very easy, once you get familiar with it, and LinuxCNC is very, very good as everything can be seen/read/checked/tested/modified/even visualised with Vismach, so it does pay off to spend some time learning it.
The best thing is, in a factory i workded, we had a mill, lathe, plasma and a "profile machining" monstrosity, all with LinuxCNC and all used by a single person.
ASUS ROG Crosshair VIII Impact - AMD X570
Moderators: PCW, jmelson
Time to create page: 0.436 seconds
