7i96S PSU
- Project_Hopeless
- Thank you received: 10
Or how about a cell phone charger? Got plenty of those.
- spumco
- Thank you received: 905
A 5v cell phone charger I hacked in there has been fine for a few months. I've got a Meanwell waiting for it to die, but haven't bothered to stick it in yet.
- Thank you received: 4152
I would stick to a Meanwell MDR-10-5 (2 amp) or a bit higher... DIN rail mount or similar.
- Thank you received: 7490
-avoid cheap china ones
-most buck converters work, but vary voltage with change in temperature, so i set them at 4.7-4.9V.
-never use buck/boost converters to power Mesa or relays.
- Unlogic
- Thank you received: 128
Given that the 5v supply powers the logic section of the board I'd have to agree with rodw. It's the wrong part of the build to cut corners. The Meanwell power supplies are a safe bet and not too expensive.There have been a number of reports of people having problems with USB/phone chargers.
- spumco
You're both right, of course, about not cutting corners here; no argument from me on that one.
As long as the OP stays away from cheapo buck converters, that's the important part.
- Project_Hopeless
I was hopping to get away with a single PSU for the system, control boards and step drivers.rodw post=300008 userid=20660There have been a number of reports of people having problems with USB/phone chargers.
So a RS style Meanwell would also work?
- spumco
I've got one of their triples (5/12/24) running in a plasma.
As fas as steppers are concerned, 48 volts is much better (if supported by your drivers) so you really end up needing 3 power supplies.
All new PC power supplies i have dismantled have a 12V rail only and the rest is done by dc-dc converters.
Word of warning though, they easily do 50 to 100A at 12V so shorts are very sparky!
They also have very good protections. In short, they are much higher quality than Meanwell, by far.
