Mesa Analog Vs Step Dir
2 years 5 months ago - 2 years 5 months ago #300780 by anfänger
Replied by anfänger on topic Mesa Analog Vs Step Dir
I checks my order and should have a 7I97 Ethernet interfaced Analog servo plus I/O and a 7IA0 Isolated remote I/O card running in this machine right now. At least according to my order from back then.
Last edit: 2 years 5 months ago by anfänger.
2 years 5 months ago - 2 years 5 months ago #300781 by PCW
Replied by PCW on topic Mesa Analog Vs Step Dir
OK I'll make 7I97/7I85S firmware
Did this need any other features?
Last edit: 2 years 5 months ago by PCW.
2 years 5 months ago - 2 years 5 months ago #300782 by anfänger
No the rest should be pretty stock, just need to know how the step Dir ist setup to configure the drivers.
is if there is one pin step+ and one step-
or one pin step and the other direction.
again thanks for your kind support
2 years 5 months ago #300784 by PCW
Firmware for a 7I97 + 7I85S
Note that a full configuration will not fit so I dropped 1 stepgen.
(so only 3 step/dir channels)  I could drop encoders (out of the 10 total)
if that's a better fit
The 7I85S has differential stepgen outputs so you have STEP+,STEP-,DIR+,DIR-
If you only need single ended outputs, you just leave the unused outputs unconnected.
File Name: 7i97_7i85sd.zip
File Size:127.45 KB
2 years 5 months ago - 2 years 5 months ago #300800 by anfänger
Many thanks, I would need all four Stepgen ( single ended) I don’t need all encoders, eight would be the max. If I want to read the servo and axis encoders.
I could also Not use one of the pwm channels.
Just out of curiosity can the stepgen outputs be setup so step+/- is a step in cw and dir+/- a step in ccw
my drivers can handle both it’s just to know for future projects
2 years 5 months ago #300803 by besriworld
Replied by besriworld on topic Mesa Analog Vs Step Dir
linuxcnc.org/docs/html/man/man9/hostmot2.9.html#stepgen
Yes, it can. Maybe it makes more sense in quadrature mode? And I'm interested in what PCW thinks.
Moderators: PCW, jmelson
Time to create page: 0.175 seconds
