- Thank you received: 599
You could use MesaCT to read the HMID and PD from the card as well as verify the card is found.Thank you both for your quick responses.
To answer Tommylight, I wasn't attempting to flash it. I wanted to use mesaflash to read its current info, and verify the board is working. The manual I was reading stated mesaflash 3.4.5 or later was required. When I was unable to communicate with or recognize the board using mesaflash 3.4.9, I thought I had a dud. Now, thanks to PCW I know that I need 3.5.3 or newer. At this time github has 3.4.9 listed as master. Since ping works and I do not need to flash the card I will continue on with my fears of a dud alleviated.
github.com/LinuxCNC/mesaflash there is a quickstart instructions at the bottom of that page to build and install mesaflash.Thank you kindly PCW for your reply.
This might be a very stupid question, but how do I implement the link you provided into MesaCT?
Do Just download the last hostmot2.c and mesaflash.c files and swap them into the mesa flash-master folder?
Excuse my ignorance!
j
