Driving relay using NO, COM and or NC
- garthnoakes
- Thank you received: 9
06 Jul 2024 09:22 #304522
by garthnoakes
Driving relay using NO, COM and or NC was created by garthnoakes
I have a SainSmart 5 Axis Breakout Board for Stepper Motor Driver CNC Mill board. I want to drive a hot wire relay with it. It has NO, COM, NC connectors - how do I wire these to the relay, and how is Linuxcnc configured for this? I connected the inputs to ground and NO, but an M3 does not trigger the relay
- Thank you received: 2177
06 Jul 2024 10:26 #304524
Replied by Aciera on topic Driving relay using NO, COM and or NC
- Thank you received: 426
06 Jul 2024 10:28 #304525
Replied by Cant do this anymore bye all on topic Driving relay using NO, COM and or NC
NO,COM,NC are (usually) the switched side of the relay.
Where are the coil connections connected to ?
Could you do a quick sketch of how you've wired the relay, you're description isn't quite clear.
If you want to drive a relay via another relay, connect one of the coil terminals on the relay you want to dirve to the + power rail, the the other terminal to the NC or NO depending on whether activating the first relay turns the second relay on or off and connect the COM to the ground of the power supply that the coil of the second relay is connected to.
- garthnoakes
06 Jul 2024 11:41 #304527
by garthnoakes
Replied by garthnoakes on topic Driving relay using NO, COM and or NC
I have this relay
www.amazon.com/gp/product/B01B60LPVK/ref..._title?ie=UTF8&psc=1
And this board
www.amazon.com/gp/product/B0093Y897A/ref..._title?ie=UTF8&psc=1
I've used X, Y, Z and A for the hot wire motors (XYUV), so besides the 5v and B output pins and the input pins, everything is used besides the NO/COM/NC connectors
And this board
- garthnoakes
06 Jul 2024 12:16 #304529
by garthnoakes
I found when I send an M3 and M5 that I can hear the onboard relay clicking on and off. So the config is correct (NO is pin 14) - I just dont know how to connect the onboard relay to the external relay
06 Jul 2024 12:34 - 06 Jul 2024 12:37 #304532
External Relay Yellow wire to +5v
External Relay Blue wire to on board relay NO if onboard relay turns external relay on
OR
External Relay Blue wire to on board relay NC if onboard relay turns external relay off
On board relay common to ground of the above +5v supply
Imagine the on board relay is a switch. Pretty much what I said in my first post, but now with colours
OR
Last edit: 06 Jul 2024 12:37 by Cant do this anymore bye all.
- garthnoakes
06 Jul 2024 12:51 #304534
by garthnoakes
I think my board is faulty - getting nothing (AC or DC) from ground to the 5V connector. I've tested using ground/COM etc - all combinations. The relay light on the board switches on and off though. Going to order a new board - I want a spare anyway (I'm cutting several thousand pieces of foam)
06 Jul 2024 13:04 #304536
The relay contacts will have no voltage on them, that's why the one lead on the external relay needs to be connected to +5v and the common of the on board relay connects to ground. If you look at the diagram of the relay posted you will see what I mean.
The Bob board supplies no voltage to any on the NC NO COM or common contacts on the on board relay. Your board is not faulty. Get a multimeter use the resistance setting or continuity setting and place it across the NO & COM conatcs of the on board relay, the relay is just a couple of switch contacts activated by an electromagnet, as with a switch there is no power on the contacts until you supply that power. The power doesn't maigically appear on the contacts, it has to come from somewhere.
If you follow my description it will work.
- garthnoakes
06 Jul 2024 13:12 #304537
by garthnoakes
Thanks - the continuity between NO and COM is working. I need some sleep now - so I can think straight again. Your help is much appreciated though
06 Jul 2024 13:12 - 06 Jul 2024 13:26 #304538
Last edit: 06 Jul 2024 13:26 by Cant do this anymore bye all.
The following user(s) said Thank You: GeckoWorks
Time to create page: 0.299 seconds
