MESA 7c81 HELP!
2 years 2 months ago - 2 years 2 months ago #307742 by PCW
Replied by PCW on topic MESA 7c81 HELP!
You might take a LED+resistor or DVM and check that the
direction pin changes state when jogging in different directions.
I would probably also change:
loadrt hm2_rpspi config="firmware=hm2/7c81/5ABOBX3.BIT num_encoders=1 num_pwmgens=3 num_stepgens=10"
to:
loadrt hm2_rpspi config="num_encoders=1 num_pwmgens=0 num_stepgens=3"
Unless you need a PWMgen or encoder or 10 stepgens
Last edit: 2 years 2 months ago by PCW.
2 years 2 months ago #307843 by waukeenahBob
Replied by waukeenahBob on topic MESA 7c81 HELP!
Changing the encoders pwm gens and step gens made a HUGE difference...
Not sure I understand why... sounds like I need to do some reading on how that driver or maybe linuxcnc works... recommendations?
My steppers now move... unfortunately they are stuttering and making a horrible noise.... I suspect that is all about tuning the settings. If so can you point me to a document on how to develop the tuning parameters?
THANKS!!
2 years 2 months ago - 2 years 2 months ago #307844 by PCW
You have the PID P terms set so high that they will cause oscillation.
You should use 1/servo-period which is the pncconf default = 1000
for a 1ms servo thread rate.
The physical meaning of a 1/servo thread P term is that position errors
are corrected by the next servo thread invocation. A value of 10000
(with a 1ms servo thread rate) means that a sensed stepgen position
error will be overcorrected by a factor of 9, leading to oscillation.
In addition:
setp hm2_7c81.0.dpll.01.timer-us -50
should probably be changed to
setp hm2_7c81.0.dpll.01.timer-us -200
Moderators: PCW, jmelson
