7i76E rev B versus 7i76E rev C
2 years 1 month ago #309447 by knipknap
After searching for more than a year or two I finally got hold of a replacement 7176E, as on my old one one of the servo channels stopped working.
On the 7i76E I received I see that it is HW Rev B (my old one was Rev C).
After inserting the new card I noticed that the spindle control doesn't work.
Is there a difference between these two revisions that could explain why it doesn't work?
2 years 1 month ago #309449 by PCW
Replied by PCW on topic 7i76E rev B versus 7i76E rev C
No, the only differences between 7I76E versions is that the overvoltage
protection is better on the C rev cards and the field power regulator uses
a different chip. The spindle interface is identical.
The following user(s) said Thank You: knipknap
2 years 1 month ago #309453 by knipknap
Ok thanks. Looks like the new one is also defective then :-(
2 years 1 month ago #309455 by PCW
For simple isolated issues (like a step/dir channel failure or spindle issue)
It is possible to repair the card
2 years 1 month ago #309457 by knipknap
Good to know - I am in the EU though, not sure that is feasible here.
2 years 1 month ago #309468 by PCW
If you have one working card you could choose the slowest/cheapest shipping option for
the other card Also both issues (damaged step/dir output or damaged spindle output)
are relatively easy  to repair if you have a nearby person with SMT repair ability
(the affected parts are known and inexpensive)
Moderators: PCW, jmelson
Time to create page: 0.367 seconds
