7i76E rev B versus 7i76E rev C
- knipknap
- Thank you received: 6
05 Sep 2024 18:44 #309447
by knipknap
7i76E rev B versus 7i76E rev C was created by knipknap
After searching for more than a year or two I finally got hold of a replacement 7176E, as on my old one one of the servo channels stopped working.
On the 7i76E I received I see that it is HW Rev B (my old one was Rev C).
After inserting the new card I noticed that the spindle control doesn't work.
Is there a difference between these two revisions that could explain why it doesn't work?
- Thank you received: 5334
05 Sep 2024 18:51 #309449
Replied by PCW on topic 7i76E rev B versus 7i76E rev C
No, the only differences between 7I76E versions is that the overvoltage
protection is better on the C rev cards and the field power regulator uses
a different chip. The spindle interface is identical.
The following user(s) said Thank You: knipknap
- knipknap
05 Sep 2024 19:06 #309453
by knipknap
Replied by knipknap on topic 7i76E rev B versus 7i76E rev C
Ok thanks. Looks like the new one is also defective then
05 Sep 2024 19:13 #309455
For simple isolated issues (like a step/dir channel failure or spindle issue)
It is possible to repair the card
- knipknap
05 Sep 2024 19:26 #309457
by knipknap
Good to know - I am in the EU though, not sure that is feasible here.
05 Sep 2024 21:12 #309468
If you have one working card you could choose the slowest/cheapest shipping option for
the other card Also both issues (damaged step/dir output or damaged spindle output)
are relatively easy to repair if you have a nearby person with SMT repair ability
(the affected parts are known and inexpensive)
- knipknap
06 Sep 2024 14:27 #309500
by knipknap
I found someone to help me with that (YouTube channel talla83), thanks a lot!
Time to create page: 0.712 seconds
