Xilinx Setup to edit config for 7i92T
26 Nov 2024 22:09 - 26 Nov 2024 22:10 #315321 by StoneB
Hello, I am trying to set up my 7i92T for my existing controller (a Mechapro Slider SFX), and am struggling with the very first step: I have tried the two computers in the house (Windows 11) and both refuse to install the Xilinx Software ("Virtualization needs to be enabled"). I have made sure the BIOS virtualization is on, and have also tried some youtube trick to install Oracle Virtualbox already - but no success so far.
Is there any further trick I miss?
Alternatively, I thought I could use Raspi I want to run LinuxCNC on, but I have no idea if I can install the 4 .xz packages: do I need to unzip them all four in the same folder? How do I trigger install on Linux?
Or, if anybody has the software already installed for a 7i92T, would you be willing to program it with the below ports?
Thank you!!
P2: LPT 1 (Slider SFX)
IO Connections for P2
DB25 pin#             I/O   Pri. funk    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                      0   IOPort       None
14                      1   IOPort       PWM              1        PWM             (Out)
 2                      2   IOPort       StepGen          0        Dir/Table2      (Out)
15                      3   IOPort       None
 3                      4   IOPort       StepGen          0        Step/Table1     (Out)
16                      5   IOPort       PWM              1        PWM             (Out)     (Toggle @ 250Mhz: Assume it needs to be a PWM)
 4                      6   IOPort       StepGen          1        Dir/Table1      (Out)
17                      7   IOPort       None
 5                      8   IOPort       StepGen          1        Step/Table1     (Out)
 6                      9   IOPort       StepGen          2        Dir/Table2      (Out)
 7                     10   IOPort       StepGen          2        Step/Table1     (Out)
 8                     11   IOPort       StepGen          3        Dir/Table2      (Out)
 9                     12   IOPort       StepGen          3        Step/Table1     (Out)
10                     13   IOPort       None
11                     14   IOPort       None
12                     15   IOPort       None
13                     16   IOPort       None
P1: IO & Encoder (Pendant & Future Spindle)
IO Connections for P1
DB25 pin#             I/O   Pri. func    Sec. func        Chan     Sec. Pin func   Sec. Pin Dir
 1                     17   IOPort       None
14                     18   IOPort       QCount           1        Quad-A          (In)
 2                     19   IOPort       None
15                     20   IOPort       QCount           1        Quad-B          (In)
 3                     21   IOPort       None
16                     22   IOPort       QCount           1        Quad-IDX        (In)
 4                     23   IOPort       None
17                     24   IOPort       None
 5                     25   IOPort       None
 6                     26   IOPort       None
 7                     27   IOPort       None
 8                     28   IOPort       None
 9                     29   IOPort       None
10                     30   IOPort       QCount           1        Quad-A          (In)
11                     31   IOPort       QCount           1        Quad-B          (In)
12                     32   IOPort       QCount           1        Quad-IDX        (In)
13                     33   IOPort       None
Slider SFX Pinout
Pin 1 Relay 1, e.g. main spindle on/off
Pin 2 Direction motor X
Pin 3 Clock motor X
Pin 4 Direction motor Y
Pin 5 Clock motor Y
Pin 6 Direction motor Z
Pin 7 Clock motor Z
Pin 8 Direction motor 4
Pin 9 Clock motor 4
Pin 10-13 Forwarded inputs, e.g. for signals from limit and
 reference switches
Pin 14 PWM signal
Pin 15 Output for ready signal
Pin 16 Toggle signal
Pin 17 Current reduction input (active low)
Pin 18-25 Signal ground (0V, GND)
Last edit: 26 Nov 2024 22:10 by StoneB.
  • Platinum Member
  • Platinum Member
26 Nov 2024 22:50 #315326 by Cant do this anymore bye all
Replied by Cant do this anymore bye all on topic Xilinx Setup to edit config for 7i92T
Regrading the Rpi there is a pre made image. Look on the Linuxcnc home page and go to the downloads section.
Regarding Xilinx ISE I can't recall having to have Virtualization on. Make sure you are using ISE 14.7 or less as Vivado doesn't support the spartan 6.
Pete from Mesa will usually build a new config for users, so just be patient.
For info on installing ISE
wiki.linuxcnc.org/cgi-bin/wiki.pl?Editing_MESA_Bitfiles
Unfornately the images are unavailable.
26 Nov 2024 23:13 - 26 Nov 2024 23:14 #315329 by PCW
Replied by PCW on topic Xilinx Setup to edit config for 7i92T
If you have a 7I92T you need the Efinix tool set (Efinity) not the Xilinx tool set
The pinout looks almost identical to the G540 pinout except the step/dir pins are swapped,
so 7i92t_g540d.bin could be used if it's not too much of an issue to physically swap the
step/dir pins.
Note that for the charge-pump, a stepgen is normally used (and pncconf knows how to set this up)
If swapping the step/dir pins is too much of a pain, I can either build firmware with the more advanced stepgens
the can swap output pins (so its still a g540 configuration but with some added stepgen features)
or make a custom configuration. It is a fair nuisance to setup the tools so maybe not worth it for one configuration
that I can do a a few minutes.
Last edit: 26 Nov 2024 23:14 by PCW.
  • Platinum Member
  • Platinum Member
27 Nov 2024 03:06 #315337 by Cant do this anymore bye all
My only excuse is it 3 million degrees Celsius in Sydney ATM
08 Dec 2024 10:34 #316238 by StoneB
Replied by StoneB on topic Xilinx Setup to edit config for 7i92T
Thanks PCW and cornholio for your pointers!
I would really want to try a custom firmware as the card will interface with two pre-existing connectors / controllers within a very tight space - adding a DB25 cable which reroutes the ports will be an absolute pain
I have now Efinix loaded and running, and I have found how to load the 7i92t-hm2 project (I assume from other forum posts that the 7i92t25 is for larger projects and so not applicable for me). I'm not able to find a pointer as to where to edit my pins? I read that I need to edit seveni92t.peri.xml but that file looks daunting: how I find which pins (of the two ports) are meant?
Also, thanks for the pointer regarding toggle: I have amended my notes, does it work to have just one Step, or do they need to come in step/dir pairs?
 1                      0   IOPort       None
15                      3   IOPort       None
16                      5   IOPort       StepGen          4        Step/Table1     (Out)     (Toggle 250Mhz PWM)
17                      7   IOPort       None
10                     13   IOPort       None
11                     14   IOPort       None
12                     15   IOPort       None
13                     16   IOPort       None
 1                     17   IOPort       None
 2                     19   IOPort       None
 3                     21   IOPort       None
 4                     23   IOPort       None
17                     24   IOPort       None
 5                     25   IOPort       None
 6                     26   IOPort       None
 7                     27   IOPort       None
 8                     28   IOPort       None
 9                     29   IOPort       None
13                     33   IOPort       None
Slider SFX Pinout
Pin 3 Clock motor X
Pin 5 Clock motor Y
Pin 7 Clock motor Z
Pin 9 Clock motor 4
 reference switches
Pin 14 PWM signal
Thanks for your patient help :)
08 Dec 2024 14:15 - 08 Dec 2024 14:35 #316246 by PCW
The pinout is determined by the pinout file (PINXXXX.vhd)
This file is identical for Xilinx or Efinix chips. Basically to make
a new pinout, you copy an existing pinout file ( one that's similar
to what you want) to your new pinout file, edit that file to match
the required pinout and module counts. Add that new file to
the project  (with "Edit Project" --> "Design" -->  "Add design file")
and include  it in the toplevel source file (TopEthernet16HostMot2_efx.vhd)
by adding it like this:
--use work.PIN_7I85SD_7I76_SSI_34.all;
--use work.PIN_PMDX126x2_34.all;
use work.PIN_NEWPINOUTFILE_34.all;  <<<<<<<<
--use work.PIN_7I85S_4PWMD_34.all;
--use work.PIN_APSX_SWISS.all;
--use work.PIN_IOONLY_34.all;
--use work.PIN_ST8_RC8_34.all;
Note that only one pinout file is uncommented
The .xml files are for the project manager and the interface designer
you do not edit them directly, nor do you change anything with the interface
designer unless you have different hardware (a custom FPGA card for example)
Last edit: 08 Dec 2024 14:35 by PCW.
13 Dec 2024 12:23 - 13 Dec 2024 12:24 #316572 by StoneB
I think I made all the modifications needed (and included my PIN_Slidersfx file in the TopEthernet16HostMot2_efx).
When I now try to synthesize, I get the error "pin_slidersfxg_34 not compiled in library 'gui_analyze'. Should I call my file in another file too?
Thanks!
Last edit: 13 Dec 2024 12:24 by StoneB.
13 Dec 2024 15:40 #316582 by PCW
Did you add your new pin file to the project?
13 Dec 2024 17:10 #316597 by StoneB
I did - it appears in the design - that's how it should be, right?
The error that stops Synthesis is:ERROR : ***\7i92t\configs\hostmot2\source\7i92t-hm2\TopEthernet16HostMot2_efx.vhd(135): 'pin_slidersfxg_34' is not compiled in library 'efxlib' [VHDL-1240]
Here are my two edited files:
File Name: PIN_SLIDERSFXG_34.zip
File Size:10 KB
13 Dec 2024 17:53 #316600 by PCW
You have the old (G540) package name in your pinout file
Moderators: PCW, jmelson
Time to create page: 0.139 seconds
