W5100S-EVB-PICO stepgenerator and encoder driver
1 year 5 months ago #329055 by COFHAL
When I open this link: developer.arm.com/downloads/-/gnu-rm , it says: This page is deprecated. See Arm GNU Toolchain for updated content and latest releases. Arm GNU Toolchain.
If I follow Arm GNU Toolchain, many download options appear. Which one should I download?
The truth is, I have little experience doing this type of installation from scratch, and it seems like what you've written on your Github is for experts. I don't know if there's a way to do all these processes automatically with bash.
1 year 5 months ago #329071 by atrex77
Precompiled .uf2 in the repository binary directory, you not need to rebuild the project if you want to use
The following user(s) said Thank You: COFHAL
1 year 5 months ago - 1 year 5 months ago #329072 by atrex77
The hal driver installation is easy, you need to open terminal navigate to the hal-driver directory and run ./install.sh
Sample hal configuration in the hal-driver/test_config directory
Last edit: 1 year 5 months ago by atrex77.
1 year 5 months ago #329125 by atrex77
!UPDATE!
the default settings in the code makes the:
4 stepgenerator (up to 512 Khz in 1ms servo thread)
2 quadrature encoder counter (example: 1 for spindle encoder 1 for MPG)
3 digital outputs
1 pwm output (from 1.9Khz - 1Mhz varies from 7bit to 16bit resolution, depends of the frequency)
4 digital inputs
docs how to change this is in progress
The following user(s) said Thank You: meister, COFHAL
1 year 5 months ago #329178 by COFHAL
What is the bianari file for the normal RP pico?
stepper-ninja-W5500 or stepper-ninja-W5500S
1 year 5 months ago - 1 year 5 months ago #329193 by atrex77
the stepper-ninja-w5500.uf2 is the file you need if you make like this.
the pico only is not enough, you need a w5500 module also, or a W5100S-EVB-PICO
Moderators: PCW, jmelson
Time to create page: 0.073 seconds
