MESA 7i76E burning out issue
1 year 5 months ago #329057 by PCW
Replied by PCW on topic MESA 7i76E burning out issue
Perhaps an output is marginal because of previous damage
I would verify full 5V swing on all step/dir pins.
Here is a simple script to toggle all stepgen step and direction pins slowly:
File Name: stepgens_2...5-24.txt
File Size:1.33 KB
Download then
chmod +x stepgens.txt
and
./stepgens.txt to run
Note that this needs a relatively recent mesaflash
github.com/LinuxCNC/mesaflash
1 year 5 months ago #329063 by knipknap
Thanks a lot for your help!
Now that I hooked up an oscilloscope, the problem disappeared completely again - can't reproduce it anymore, at all.
That made generating pulses easier of course, I simply jogged the thing along. The levels of the step+/- pins on the motor side are around 4.8 volts, and -4.8 on a pulse.
I also noticed that the level between STEP- and the cable shield (GND) is around 40 volts AC (50 Hz). I can't say I understand why that would be so. Is that normal/intended?
1 year 5 months ago #329070 by PCW
Ack!! 40V is a real issue and indicates a grounding problem. This likely
what damaged the step/dir outputs (accidental contact to shield ground would do it)
I would verify that the drive frame grounds connect to earth ground and that the
7I76E ground (24V logic power ground) is also connected to earth ground.
The following user(s) said Thank You: knipknap
1 year 5 months ago #329073 by knipknap
Ah-ha! The 24V field power GND is not connected to earth ground, I was not sure that it should be. That probably explains it then.
Just weird that the machine ran fine for so long.
Thanks, I was getting frustrated with the constantly changing symptoms. I will connect those grounds tomorrow and test again.
1 year 5 months ago #329099 by knipknap
So, change made, AC power component is gone and first small test job ran successfully. Hoping for the best :-). Thank you again!
1 year 4 months ago #330567 by knipknap
I finally found the real cause.
Today i got the amplifier fault on another joint (joint 0) and I found that it the problem happened whenever I turned on the spindle.
After several attempts to measure the ground connections the machine stopped in a position where I found the machine frame was not grounded.
The reason: The spindle connector got loose. The machine frame was grounded through the spindle cable, and that cable had become loose.
All I had to do was tighten the screw of the connector. Ground connection works reliably again and the machine runs well. Phew.
Moderators: PCW, jmelson
Time to create page: 0.070 seconds
