5 axis milling machine with 7i96s
- Gautham
- Thank you received: 3
11 Jul 2025 06:00 #331688
by Gautham
5 axis milling machine with 7i96s was created by Gautham
Hi Everyone,
I am new here and new to CNC, Linux and Mesa boards, so pls excuse the novice questions.
This is my setup
I have a 5-axis milling machine, which uses 2 stepper motors for the z axis, so in total there are 6 stepper motors. I have also bought a servo motor ECMA-C21020RS from Delta to power my spindle. I have a Mesa 7i96s card
Now for my question
Have I bought the wrong Mesa card for my requirement? From my understanding, the 7i96s can only control 5 motors so my 6 steppers and servo exceed the capacity. If so, what would be the best solution? To buy another card and scrap the 7i96 or is there an option to buy an add-on card to work with the 7i96s?
Thank you in advance for your help
This is my setup
Now for my question
- Gautham
11 Jul 2025 07:08 #331689
by Gautham
Replied by Gautham on topic 5 axis milling machine with 7i96s
I wanted to add that my machine also has a parallel port available, if that would help
- Thank you received: 5334
11 Jul 2025 13:15 - 11 Jul 2025 20:56 #331701
Replied by PCW on topic 5 axis milling machine with 7i96s
You can add a daughter card to the 7I96S parallel expansion port.
You could use a Mesa daughterboard (a 7I85S or 7I78 would add 4 step/dir axis).
You could also use an inexpensive parallel port breakout, like the common Sainsmart
5 Axis breakout, either ST-V2 or ST-V3 or one of the many similar parallel port
breakouts.
breakouts.
Last edit: 11 Jul 2025 20:56 by PCW.
- jimmyrig
- Thank you received: 42
13 Jul 2025 06:02 #331757
by jimmyrig
Replied by jimmyrig on topic 5 axis milling machine with 7i96s
As PC's said,
Your 7i96s is perfectly capable of driving at least 10 axis.
The process is
Use mesaflash to upload the 7i96 5bob firmware. That will allow you to use the additional axis.
I've done this with 2 separate installs and no issues.
The process is
- Gautham
14 Jul 2025 05:32 #331804
by Gautham
Thank you so much PCW and Jimmy, I will do more research into the options you have both suggested and see which would be easier for me to implement.
- Gautham
14 Jul 2025 08:26 - 14 Jul 2025 08:27 #331808
by Gautham
Hi PCW,
I found a card locally that seems similar to the Sainsmart breakout you had mentioned. I'll add the link below. It says its for Mach3 and LinuxCnc, would this work with my Mesa 7i96s. Thanks so much for your help. Interface Board CNC 5 Axis
Last edit: 14 Jul 2025 08:27 by Gautham.
14 Jul 2025 15:14 #331820
will work with that.
Yes, that looks exactly like a Sainsmart ST-V2 so 7i96s_5abobd.bin firmwareHi PCW,
- Gautham
15 Jul 2025 04:20 #331843
by Gautham
- Gautham
25 Aug 2025 10:03 - 25 Aug 2025 10:11 #333891
by Gautham
Hi again,So I finally got this
BoB,
and I have wired up everything according to this
video tutorial
I found, but I don't know how to configure my B-axis to run through the BoB on LinuxCNC. I also managed to flash the 7i96s_5abobd.bin firmware to the mesa card but I'm not sure how to proceed on LinuxCNC
Thank you so much for your help.
Last edit: 25 Aug 2025 10:11 by Gautham. Reason: adding some more info
25 Aug 2025 15:04 #333908
I would probably use pncconfs discovery option so pncconf knows about the
additional stepgens so you can configure the B axis.
Time to create page: 0.142 seconds
