Driving my SyilX3 and Plasma cutter machine with 5i25t which provided driver?
1 year 1 month ago #334638
by joego
Replied by joego on topic Driving my SyilX3 and Plasma cutter machine with 5i25t which provided driver?
So I attached a schematic with the pinouts in my previous post. I'm interested in learning what the process is for creating the firmware for a situation like mine where I do not have a daughter card. Do I load on of the provided files and modify the pinfile?
1 year 1 month ago #334645
Replied by PCW on topic Driving my SyilX3 and Plasma cutter machine with 5i25t which provided driver?
The basic process is to take a close pinout source file (PIN_XXXXX.vhd)
copy it to a new file and edit that new file to get the desired pinout
and modules needed. Then this new file is added to the project
and included in the top level file, and finally compiled into the new
firmware binary file.
Do you know which pins on your schematic are step and dir?
(the LinuxCNC parallel port hal file would help here)
I ask because it's quite likely an existing firmware file will either
work without changes, or at least its pinout source file would be a
good starting point to making a custom configuration
1 year 1 month ago #334667
by joego
OK, will get the hal file.
1 year 1 month ago #334723
by joego
HI, I have attached the hal file directory.
Thank you for the help!
1 year 1 month ago #334728
Here's a basic try at this using the stepgen mapping:
0 = X
1 = Y
2 = Z
3 = A
The zip file includes the firmware and the modified pinout source file
0 = X
1 = Y
2 = Z
3 = A
The following user(s) said Thank You: joego
1 year 1 month ago - 1 year 1 month ago #334846
by joego
Thanks for the file!
Last edit: 1 year 1 month ago by joego.
Time to create page: 0.057 seconds
