Firmware Request for 7i92 – Plasma CNC Build
1 year 1 month ago #335164 by souh-hil
 Hello everyone,This is my first post here on the LinuxCNC forum, and also my very first CNC build — so please forgive any mistakes or lack of experience on my part. I'm doing my best to learn as I go.I'm building a plasma CNC machine and using a Mesa 7i92 card. For my setup, I’ll be connecting two 5-axis breakout boards — one on P1 and one on P2. I’m looking for a suitable firmware that would allow me to:
  • Use 4 or 5 encoder inputs (for THCAD and potentially other uses)
  • Have at least 10 inputs and 5 outputs for general machine control
I’ve checked the Mesa site and the firmware list, but I’m not sure which bitfile would suit this configuration best. If anyone has a firmware file that fits these needs — or could point me in the right direction — I would be very grateful.Thank you so much in advance for your help and patience. I really appreciate the knowledge and support shared in this community.Best regards,
1 year 1 month ago #335170 by PCW
For a 7I92:
7i92_5ABOBx2D.bit
for a 7I92T:
7i92t_5abobx2d.bin
Would be closest If you are using the common "Mach 5 Axis" Sainsmart parallel port BOB
Note that the inputs of the common 5 Axis breakouts are not really suitable for encoder use
as they are quite slow and require 12 V signals.
The following user(s) said Thank You: souh-hil
1 year 1 month ago #335177 by souh-hil
Yes, I'm using the common 5-axis BOBs from china, one on each port (P1 and P2).
That said, I don’t actually need all 10 StepGen channels. My machine only uses 4 axes, so I’m hoping to free up many of the StepGen-related I/O pins and use them as general-purpose I/Os instead.
Also, since the 7i92 headers are mirrored (P1 and P2), both BOBs give access to the same type of GPIO pins. I’m hoping to take advantage of that symmetry and assign more pins for inputs (e.g., limit switches, ArcOK, ohmic probe, thc UP /down etc.), and just a few for outputs (torch on/off, float switch reset, laser etc.).
Ideally, I'd like a bitfile that allows:
At least 10 inputs and 5 outputs for general machine control
Fewer StepGen channels (maybe 4 or 5 max)
If a bitfile like that exists — or if modifying an existing one is straightforward — I’d really appreciate the guidance.
Thanks again for your help!
Best regards,
1 year 1 month ago #335178 by tommylight
Any stepgen or encoder that is not in use, it's pins can be used as IO, so if you just load
loadrt num_stepgens = 4
that will enable 4 stepgens on the first port (no idea exactly if P1 or P2) and the rest of the 26 pins can be used freely as inputs or as outputs.
Use
mesaflash --card_name --IP --readhmid
replace name and IP with what you have and check the resulting pin assignment so you can decide how many stepgens and encoders you need and what pins they use, from that you know what pin numbers remain for inputs and outputs.
BUT, since you are using BOB's, you will be limited to what the BOB uses as inputs ( 10 in total for encoders and switches) and 24 as outputs.
1 year 1 month ago #335180 by PCW
A picture or link to the actual breakout board you have would be helpful.
As tommylight noted, the common "5 Axis CNC" breakout has 12 outputs
and 5 inputs and this is fixed by the breakout board hardware.
The following user(s) said Thank You: tommylight, souh-hil
1 year 1 month ago #335191 by souh-hil
Hi all,Thanks in advance to everyone who responds!I’m using the following HostMot2 bitfile for my Mesa 7i92:
BoardName : MESA7I92
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 100.0000 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 100.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: QCount
There are 6 of QCount in configuration
Version: 2
Registers: 5
BaseAddress: 3000
Module: StepGen
There are 5 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P2
Pin#  I/O   Pri. func    Sec. func       Chan      Pin func        Pin Dir
 1      0   IOPort       PWM              0        PWM             (Out)
14      1   IOPort       None
 2      2   IOPort       StepGen          0        Step/Table1     (Out)
15      3   IOPort       None
 3      4   IOPort       StepGen          0        Dir/Table2      (Out)
16      5   IOPort       StepGen          4        Step/Table1     (Out)
 4      6   IOPort       StepGen          1        Step/Table1     (Out)
17      7   IOPort       StepGen          4        Dir/Table2      (Out)
 5      8   IOPort       StepGen          1        Dir/Table2      (Out)
 6      9   IOPort       StepGen          2        Step/Table1     (Out)
 7     10   IOPort       StepGen          2        Dir/Table2      (Out)
 8     11   IOPort       StepGen          3        Step/Table1     (Out)
 9     12   IOPort       StepGen          3        Dir/Table2      (Out)
10     13   IOPort       None
11     14   IOPort       QCount           0        Quad-A          (In)
12     15   IOPort       QCount           0        Quad-B          (In)
13     16   IOPort       QCount           0        Quad-IDX        (In)
IO Connections for P1
 1     17   IOPort       QCount           1        Quad-A          (In)
14     18   IOPort       QCount           1        Quad-B          (In)
 2     19   IOPort       QCount           1        Quad-IDX        (In)
15     20   IOPort       QCount           2        Quad-A          (In)
 3     21   IOPort       QCount           2        Quad-B          (In)
16     22   IOPort       QCount           2        Quad-IDX        (In)
 4     23   IOPort       QCount           3        Quad-A          (In)
17     24   IOPort       QCount           3        Quad-B          (In)
 5     25   IOPort       QCount           3        Quad-IDX        (In)
 6     26   IOPort       QCount           4        Quad-A          (In)
 7     27   IOPort       QCount           4        Quad-B          (In)
 8     28   IOPort       QCount           4        Quad-IDX        (In)
 9     29   IOPort       QCount           5        Quad-A          (In)
10     30   IOPort       QCount           5        Quad-B          (In)
11     31   IOPort       QCount           5        Quad-IDX        (In)
12     32   IOPort       None
13     33   IOPort       None
  1. I only need 4 axes (X, Y1, Y2, Z). Can I use the last StepGen for torch on and laser pointer outputs?
  2. I do not need encoders. Can I use the QCount pins as general-purpose inputs?
  3. Can I use the pins labeled “None” or “unassigned” in the bitfile as inputs or outputs, depending on their pin direction?For example, pins 10 and 15 as inputs, and pin 14 as output?
  4. Are pins 13 and 15 on P2 free to use as I/O?
  5. My breakout board has 5 inputs labeled P10, P11, P12, P13, and P15. Can I use all of them as inputs
thanks again to everyone who helps!Best regards,
Moderators: PCW, jmelson
Time to create page: 0.109 seconds
