Mesa 7i96s not connecting
  • Meleon
  • Topic Author
  • New Member
  • New Member
1 year 1 week ago #336788 by Meleon
Mesa 7i96s not connecting was created by Meleon
let me start by saying Hi and I am very new to linux and linuxcnc.
I've been trying to 2 days to get mesa mesa 7i96s to connect to linuxcnc.
I am running debian 13 Xfce and I have kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.12.48-1 (2025-09-20)
I have wired connection 1 Ipv4 set to manual and address set to 10.10.10.11 (routes set to use this connection only for resources on its network)
On the 7i96s I have the jumper set for eeprom.
I can ping the card at 10.10.10.10 and it appears to respond (yellow power led and green users leds lit)
but when I to launch my config file I get red led's on cr6 and cr7
and linuxcnc shuts down and gives this debugging
Note: Using POSIX realtime
hm2_eth: rtapi_app_main: Resource temporarily unavailable (-11)
./7i96s.hal:9: waitpid failed /usr/bin/rtapi_app hm2_eth
./7i96s.hal:9: /usr/bin/rtapi_app exited without becoming ready
./7i96s.hal:9: insmod for hm2_eth failed, returned -1
1868
Stopping realtime threads
Unloading hal components
I am not sure what I am missing...
1 year 1 week ago #336789 by PCW
Replied by PCW on topic Mesa 7i96s not connecting
if you get CR7 (/DONE) illuminated at any time after initial power on,
you likely have a marginal 5V supply. (CR7 is only illuminated during a
power on reset)
The following user(s) said Thank You: Meleon
  • Moderator
  • Moderator
1 year 1 week ago #336790 by tommylight
Replied by tommylight on topic Mesa 7i96s not connecting
What does
ip a
in a terminal return?
Also, did you set the IP to 10.10.10.10 in the wizard? By default it is at 192.168.1.121
  • Meleon
  • Topic Author
  • New Member
  • New Member
1 year 1 week ago #336791 by Meleon
Replied by Meleon on topic Mesa 7i96s not connecting
In the Pncconf wizard? yes I changed it to 10.10.10.10
ip a returns
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 90:b1:1c:8d:36:5f brd ff:ff:ff:ff:ff:ff
altname enp0s25
altname enx90b11c8d365f
inet 10.10.10.11/8 brd 10.255.255.255 scope global noprefixroute eno1
inet6 fe80::147c:8a67:beeb:e22a/64 scope link noprefixroute
  • Meleon
  • Topic Author
  • New Member
  • New Member
1 year 1 week ago #336793 by Meleon
Thst is possible I suppose. I am using a charging block and a modified usb cable to provide power. its measuring 5.1 volts but I can't figure out how many amps.
1 year 1 week ago #336796 by PCW
As I mentioned before, If you ever see CR7 illuminated it means power failure.
Power failure on a 7I96S means the 3.3V supply has dropped below about 3V.
This in turn means that the 5V power has dropped below about 4V (even for a few ms)
  • Meleon
  • Topic Author
  • New Member
  • New Member
1 year 1 week ago #336797 by Meleon
I'll see if I can find a better power supply
1 year 1 week ago #336815 by rodw
Replied by rodw on topic Mesa 7i96s not connecting
Use a Meanwell power supply. Say a MDR-15-5 which is 2.4 amps
  • Meleon
  • Topic Author
  • New Member
  • New Member
1 year 1 week ago #336837 by Meleon
I am borrowing an Altech din rail PSD-1505 from work for testing, (5 volt 12 watt 2.4 amp)
If that solves my problem I'll order the Meanwell.
Thanks for your help so far guys!
  • Meleon
  • Topic Author
  • New Member
  • New Member
1 year 1 week ago #336856 by Meleon
Ok new power supply hooked up. I am now able to connect to linuxcnc! Onward and upward (at least until the next hurdle)
Thanks so much everyone.
Moderators: PCW, jmelson
Time to create page: 0.065 seconds
