Mesa - Can unused step & direction outputs be used as o/p's for other purposes?
  • slowpoke
  • Topic Author
  • Elite Member
  • Elite Member
11 months 1 week ago #338811 by slowpoke
If yes, where do I find them in HALSHOW?
I'm making a little interface board and have some leftover space, so I could gain a few extra o/p points if I can take advantage of these, perhaps drive a few SSR's.
Mesa 7i96s
  • Moderator
  • Moderator
11 months 1 week ago #338814 by tommylight
All Mesa cards have the ability to use every pin as I/O if not used for special purposes, like stepgen or PWM or encoder, so you can use the step/dir of stepgen 4 (5'th stepgen) by loading just 4 stepgens.
No idea about the pinout though, been a long time, but manual should have everything explained.
11 months 1 week ago - 11 months 1 week ago #338816 by PCW
Yes, special function pins revert to GPIO if the special function is disabled in HAL
For example on a 7I96S, if you only need 4 step/dir pairs you set num_stepgens=4 in the hal file
and then the GPIO pins that would have been STEP4 and DIR4  become GPIO 25 and 26
To use these GPIO pins as outputs, you must set them into output mode:
setp hm2_7i96s.0.gpio.025.is_output true
setp hm2_7i96s.0.gpio.026.is_output true
and then link the output to the desired signal
net  some_output hm2_7i96s.0.gpio.025.out
You may need to invert the output and choose the proper + or - pin
to insure that the output is low at power up or when you exit from LinuxCNC:
setp hm2_7i96s.0.gpio.025.invert_output true
To determine the terminal block to GPIO pin mapping, look at the appropriate .pin file
or run:
mesaflash --device [cardname] --addr [card_address] --readhmid
Last edit: 11 months 1 week ago by PCW.
The following user(s) said Thank You: tommylight, pommen, slowpoke
  • slowpoke
  • Topic Author
  • Elite Member
  • Elite Member
11 months 1 week ago #338820 by slowpoke
Moderators: PCW, jmelson
Time to create page: 0.048 seconds
