- Thank you received: 39
OK, so the scan of the parallel port is getting some random stuff, since it thinks it sees a bunch of PPMC boards there.John,
Yes it is the UPWM board. It is driving your pwm servo drives. The CMOS battery did die at one point but the parallel port is set up in epp mode. I am not sure why it is doing this. If you have any troubleshooting tips I would be glad to hear them. Could the eeprom be bad?
This is the killer problem! The FPGA is not accepting the load of its program. It is somewhat unlikely the EPROM has gone bad, but possible. First, check that the +12V supply is operating properly, and does not have excessive ripple. Without a valid program in the FPGA, nothing will ever work. If the power supply is good, then it is possible the FPGA has been damaged, or one of the regulators on the board has gone bad or is overloaded. You can check from the wide tab of U31 to one of the G terminals of P2.Jon,
The load fail red led does come on and stay on when I boot up linuxcnc and get the error messages.
