7i80HD+7i48+7i42TA+7i84 Mesa firmware request (morbidelli author 503 retrofit)
9 months 1 week ago #341652 by freemoore
OK. Have done this and grounding each of these inputs produces no response from any of the pins a, b or index in halshow, on any of encoder channels 00, 01, or 02.
9 months 1 week ago #341660 by freemoore
We also have a problem with the smart serial ports in this config (via the 7i42ta): if I understand correctly, the 7i42ta pins used for the first sserial instance should be 21 and 22 (IO 45 and 46 in the firmware/readhmid result).
At the moment, whether or not "sserial_port_0=0xxxxxxx" is added to the hm2_eth line, all 7i42TA pins behave as GPIO - they can be set/cleared in halshow.
If the sserial line is added and any of its pins linked to a function, lcnc errors on startup.
9 months 1 week ago #341692 by freemoore
Huh, thought I'd posted again last thing last night but it doesn't seem to have taken.
We tried the 7i80HD-25 card with the -25 version of the firmware you sent, and with this in the system, the encoder ports are being read as expected (apart from how Yaskawa servopack C-channel vs Z-channel isn't as expected at all).
I would be grateful if you could send the firmware for that card including: 6x analogue servo, 6x encoder, 2x pktuart and 2x sserial modules, for 7i80HD-25, 7i48, 7i52 combination.
Thanks in advance!
9 months 1 week ago #341722 by PCW
This is expected behaviour: if a sserial device is not found on a particular channel, its I/O pins revert to GPIO
I'll try and get to this sometime today or tomorrow.
9 months 1 week ago #341742 by PCW
File Name: 7i80hd_25_...i52d.zip
File Size:163.76 KB
The PKTUART pins are on the two RS-485 capable 7I52 channels (the ones with TX Enables)
9 months 1 week ago #341894 by freemoore
Thanks. Now waiting on delivery of a 7i52 to test those serial ports, no luck via 7i42ta.
However, I've had trouble from the start with the 7i48 card - the 7i80HD-16 wouldn't read its encoders at all, and the 7i80HD-25 had some trouble, using encoder.00 to .03.
Last night we tried using the 7i48's encoder.04 channel with one axis at a time, and found that all 3 worked perfectly. Then we tried adding all 3 axes, at which point no aspect of the 7i48 works at all: the +15V, -15V and 3.3V lights come on, but there is no +/-10V from any AOUT port, and no encoders are read through any channel.
If a cascading fault is possible (caused perhaps by the one attempt with a 24v encoder) then I seem to have bricked my board, though I don't know if that's consistent with channel .04 having worked perfectly for half an hour of testing last night.
Please would you remake the above firmware for the 7i80HD-16? I would like to try to rule out the fpga board as the thing that's broken here, before we order another 7i48. I'd note that the reason I tried the 24v encoder was that the 7i48 wasn't reading encoder info at all to start with, though when I switched to the HD-25 it appeared to partially work, making me thing that the HD-16 firmware may have had an error.
If you have any other suggestions I'd be grateful to hear them.
Moderators: PCW, jmelson
