Connecting Arduino to MESA 7i95T through serial
  • Ameone
  • Topic Author
  • Senior Member
  • Senior Member
8 months 2 weeks ago #343150 by Ameone
Hi all,
Hope you are doing well! I'm trying to implement a status bar using a LED strip (WS2813 RGB LED - Grove) and an Arduino (uno or nano). I wanted to connect the arduino through serial communication directly to the a MESA 7i95T board, to send some string commands to the Arduino to control the LED strip behaviour.
Is it possible to do so? Can I just connect the Arduino to one of the two RS422/485 interfaces of the board? Do I need a specific firmware for the board? In case yes, my setup also includes a MESA 7i87 for reading some sensors.
Thanks,
Best,
Amedeo
8 months 2 weeks ago #343155 by meister
You can use smart serial, there are open source project on github
  • Ameone
  • Topic Author
  • Senior Member
  • Senior Member
8 months 2 weeks ago #343184 by Ameone
Great thanks! can you please point out to the correct github? I found this but I don't know if it is what you intended:
github.com/fdarling/mesa-smartserial-device-template
8 months 2 weeks ago #343185 by meister
yes, i used this 'mesa-smartserial-device-template'
to build my relay card:
github.com/multigcs/SmartSerial-ESP32RelayX8Board
but you need an esp32 or something faster than an uno/nano, because the higher serial baud-rates
Moderators: PCW, jmelson
Time to create page: 0.050 seconds
