7I77D over heat
  • okielaxplyr
  • Topic Author
  • New Member
  • New Member
8 months 1 week ago #343573 by okielaxplyr
7I77D over heat was created by okielaxplyr
I am using a optocoupler (from amazon) between my 7i77D output and a solenoid valve for a spindle break in the sinking configuration, the output is over-temperature faulting for some reason.
using TB8 OUTPUT0. Field voltage is 24Vdc and driving the relay with the same 24 power supply.
I set up the opto relay on the bench and it only draws 2.2ma on the input in low position.
I'm kind of at a loss, the manual says the outputs can take up to 350ma.
Please advise
John V.
  • Moderator
  • Moderator
8 months 1 week ago #343574 by tommylight
Replied by tommylight on topic 7I77D over heat
Moved to "driver boards".
Check the wiring, or post pictures of the wiring here so we can have a look.
8 months 1 week ago #343575 by PCW
Replied by PCW on topic 7I77D over heat
Yes, typically this is caused by  a wiring error or worst case,
a damaged 7I77D output chip.
Moderators: PCW, jmelson
Time to create page: 0.052 seconds
