chineese mesa 7i92 custom bit file
  • tykhon
  • Topic Author
  • New Member
  • New Member
7 months 4 weeks ago - 7 months 4 weeks ago #343840 by tykhon
chineese mesa 7i92 custom bit file was created by tykhon
I`m having some problems with customizing bit file to configure my mesa(clone) board. Previously I used effinity software but it seems that chineese boards running on xilinx base. Unfortunatelly I can`t download xilinx software. Could somebody help me with compiling custom bit? Pinout attached below in custom vhd file
File Name: PIN_G540x2D_34.zip
File Size:2.49 KB
Last edit: 7 months 4 weeks ago by tykhon.
7 months 4 weeks ago #343850 by tommylight
  • tykhon
  • Topic Author
  • New Member
  • New Member
7 months 4 weeks ago #343852 by tykhon
Replied by tykhon on topic chineese mesa 7i92 custom bit file
corrected
7 months 4 weeks ago #343872 by PCW
Replied by PCW on topic chineese mesa 7i92 custom bit file
I can make a (7I92) bitfile but are you sure 7I92 bitfiles will work on that card?
  • tykhon
  • Topic Author
  • New Member
  • New Member
7 months 4 weeks ago #343877 by tykhon
99%. Allready flashed it with original 7i92 bit file downloaded from mesa store support zip files. File attached was modified from that zip also.
7 months 4 weeks ago #343878 by PCW
OK I'll do this tomorrow
The following user(s) said Thank You: tykhon
7 months 4 weeks ago #343891 by RotarySMP
Replied by RotarySMP on topic chineese mesa 7i92 custom bit file
Amazing support Peter, but I really don't understand the expectation of the original post.
Your Mesa cards are very resonably priced. You have obviously put years of work into designing and updating these cards, and provide outstanding support to us here in the forum.
Someone reverse engineers your work, floods the market with knock-offs, undercuts your livelyhood, and then expects support?
You are a better person than me Peter. In your place, I would be tweaking Mesaflash to brick any knock off which gets connected to it :)
Cheers,
Mark
The following user(s) said Thank You: rodw, besriworld
7 months 4 weeks ago - 7 months 4 weeks ago #343908 by PCW
File Name: 7i92_clone.zip
File Size:85.42 KB
Note that you can download the latest Spartan6 compatible version of the Xilinx tools
(ISE Webpack 14.7) for free but you do need to register.
Last edit: 7 months 4 weeks ago by PCW.
  • tykhon
  • Topic Author
  • New Member
  • New Member
7 months 3 weeks ago #343958 by tykhon
Thank you for help. Everything works just fine. Xilinx was a bit tricky to download due to american regulations and policies. Somehow registration form doesn`t work correct. But finally I downloaded it today so this is first and last case.
Talking about original mesa cards, in my country it is almost impossible to get desired board on time. They simply out of stock. So I had to save 15$... I`m sorry.
Xilinx itself appeared an old nightmare for me to install. Heavy virtual machine, only Win7 32bit and 30-year old interface... I would not recommend customizing chineese boards after this experience.
P.S.: hope people who don`t help use Windows :)
7 months 3 weeks ago #343960 by PCW
Xilinx Webpack 14.7 runs fine on current Linux versions, no need to bother with Windows at all...
Moderators: PCW, jmelson
Time to create page: 0.143 seconds
