Mesa 7i96S, SSR output not work
5 months 3 weeks ago #346282 by japiii
I have spindle CW and CCW signals connected to out-04 and out-05. Both works fine.
I want control spindle water cooling with relay and Mesa output. I have connected relay to PB3 pins 13 and 14. When I try to control the relay, nothing happens and Mesa output led not switch on.
I bought cnc router used, so I'm not sure, what Mesa configuration I have. I have read Mesa's pinout and it shows HOSTMOT2 and I can find line
TB3-13,14              11   IOPort       SSR              0        Out-00          (Out)
If I try to control output by command "halcmd setp hm2_7i96s.0.ssr.00.out-00 true" and read state by command "halcmd show pin hm2_7i96s.0.ssr.00.out-00" state changed from false to true. Still, output led not lights up and relay not change the state.
I'm totally stucked with this and have no idea what could be wrong.
5 months 3 weeks ago #346284 by PCW
Replied by PCW on topic Mesa 7i96S, SSR output not work
If LinuxCNC is running and you have no watchdog bite (red LED on 7I96S)
and halcmd setp hm2_7i96s.0.ssr.00.out-00 true does not activate SSR0's LED,
Then its likely that the 7I96S has been damaged.
Do any SSR outputs work?
5 months 3 weeks ago #346292 by japiii
No, none of them work. So it seems, that I can't get my water pump to work with Mesa.
5 months 3 weeks ago - 5 months 3 weeks ago #346293 by PCW
If none of them work, the card has likely been damaged, possibly by
driving an inductive load with no flyback diode, or a problem with the
5V supply.
Likely damaged components are U9 (74ACT540) and possible 1 or more
MOSFETs (Q1,Q2,Q3,Q5 =  PMN55ENE or equiv)
Also just to make sure that it's not a homemade firmware issue, you might
re-write the firmware to the default 7I96S firmware:
mesaflash --device 7I96S --addr 10.10.10.10 --write 7i96s_d.bin  --reload
(replace 10.10.10.10 with 192.168.1.121 if your card is jumpered that way)
Last edit: 5 months 3 weeks ago by PCW.
5 months 3 weeks ago #346300 by japiii
I reflashed the default firmware and still same, none of SSR outputs work. It seems that I have to do some manual control for water pump.
Moderators: PCW, jmelson
Time to create page: 0.165 seconds
