Help reassign pins 7i92
  • Ismacr63
  • Topic Author
  • Elite Member
  • Elite Member
5 months 3 weeks ago #346349 by Ismacr63
Help reassign pins 7i92 was created by Ismacr63
I have a Mesa 7i92 card with the firmware file 7i92_5ABOBx2D.bit loaded, using a Chinese 5-axis breakout board on connector P2. Pins 16 and 17 are currently taken up by stepgen. Is there any way to reassign them so I can use pin 17 to control a relay and pin 16 for mist coolant?
5 months 3 weeks ago #346351 by tommylight
Replied by tommylight on topic Help reassign pins 7i92
Yes, load 4 stepgens so the unused pins revert to IO pins.
The following user(s) said Thank You: Ismacr63
  • Ismacr63
  • Topic Author
  • Elite Member
  • Elite Member
5 months 3 weeks ago #346353 by Ismacr63
Replied by Ismacr63 on topic Help reassign pins 7i92
I assume you're referring to the hal file, "num_stepgens=4"
5 months 3 weeks ago #346354 by PCW
Replied by PCW on topic Help reassign pins 7i92
Yes, but you can also do this in pncconf so the GPIO pins become
available I/O options in the configuration utility.
Moderators: PCW, jmelson
Time to create page: 0.051 seconds
