7i84U sink/source
5 months 2 weeks ago #346357 by Twitchy88
7i84U sink/source was created by Twitchy88
Hello
Looking for help on where I go to change the 7i84U outputs to sink/source. the manual says I need to change the output parameters, is this done in hal?
5 months 2 weeks ago #346360 by PCW
Replied by PCW on topic 7i84U sink/source
Yes, it's done with a setp command in the  hal file
I don't have the parameter names in front of me, but you can find
them by running:
halcmd show all | grep source
and
halcmd show all | grep sink
when LinuxCNC is running
5 months 2 weeks ago #346361 by Twitchy88
Replied by Twitchy88 on topic 7i84U sink/source
So I write setp hm2_7i96s.0.7i84.0.0.output_sink in the hal file?
I really underestimated the complexity of this.
5 months 2 weeks ago #346362 by PCW
Yes, for example to set the first 8 outputs ( 0..7 )  to sink mode
and the last 8 outputs ( 8..15 ) to source mode, you would put:
setp hm2_7i96s.0.7i84.0.0.output_sink      0x00FF
setp hm2_7i96s.0.7i84.0.0.output_source 0xFF00
In your hal file
The following user(s) said Thank You: Twitchy88
5 months 2 weeks ago #346363 by Twitchy88
I think i get it now, but can you double check what you wrote isnt backwards.
From the manual:
"Sinking mode is similarly enabled by setting the corresponding sink bit to ‘1' and source bit to ‘0'
5 months 2 weeks ago #346364 by Twitchy88
i want to make them all sinking i think its this?
setp hm2_7i96s.0.7i84.0.0.output_sink 0xffff
setp hm2_7i96s.0.7i84.0.0.output_source 0x0000
Moderators: PCW, jmelson
Time to create page: 0.453 seconds
