Can not connect to Mesa 7176eu
4 months 2 days ago #347420 by Etced
I have spent many hours searching posts and looking for answers. i just can't figure this out. I followed tommylight post on how to configure a wired ethernet connection. When I click save it comes up with a message "a gateway is incompatible with never-default.
The computer is a Lenovo m910q,  Intel Core i5-7500T . I am a total newb at linuxcnc, but successfully completed 2 mach 3 machines in the past. please help this senior citizen. Thanks
4 months 2 days ago #347428 by tommylight
Gateway, set it to 10.10.10.1 as in the how to, or just delete it as it is not used in this case when you set it for local network use, that you did not set, and that is OK if you do not use any other network but should be set nontheless.
Also, did you set the jumpers on Mesa board for 10.10.10.10? Default is 192.168.1.121, see Mesa manual.
The following user(s) said Thank You: Etced
4 months 8 hours ago #347439 by Etced
Thanks for the reply. The jumpers on board are; W3 up, W15 up, W13 down, W14 up.
4 months 7 hours ago #347441 by tommylight
4 months 3 hours ago #347445 by Etced
I have made the changes that you suggested. Still the same message appears when I hover over the save button. That button never gets highlighted.
4 months 2 hours ago #347446 by PCW
Replied by PCW on topic Can not connect to Mesa 7176eu
I would leave the gateway and DNS server entries empty
as they are meaningless here.
Moderators: PCW, jmelson
Time to create page: 0.199 seconds
