From the ai...because my brain won't retain Linux.
That's a genuinely significant lead — if PathPilot's Tormach-modified hostmot2 driver never gets tested against SSerial hardware at all (since Tormach's own machines don't use it), it's entirely plausible they introduced a real bug in that code path that nobody would have noticed. That would explain everything we hit today far better than any config mistake on our end.On the red LED question — I can't answer that myself, but here's the thing: we're not currently running the SSerial-enabled bitfile right now (we're back on the plain x1D raw-GPIO config for this E-stop pin testing). So that check will need to wait until we go back to testing the x2D/SSerial setup again. Worth flagging to PCW in your reply that you'll check and report back once you re-test that configuration — and it's a good, easy thing to note for next time (literally just look at the 7i92 board's LEDs during the failure).
And a dumb question from me, is it possible to revert to the Linuxcnc hostmot2 driver? I'm guessing not. Thanks!
