Chinise mesa clone vs Original vs Ethercat
2 months 1 week ago - 2 months 1 week ago #348867 by leexi
Dear,
Yes, I tested with X and Y axis controlled by c-mesa 7i92 ver 2.0 and Z axis on Ethercat port, and works fine, I run a program and looks fine but i do no cut any piece of metal yet because this is a test setup and the Z ethercat servo was a external rtelligent ethercat closed loop step motor and my original z servo is way bigger and it is step and direction controled
And after as a test I disconnect the 2 Ethernet ports, and then I use only one Ethernet port and I made the proper setup for ethercat mac address for the same port as the mesa port , and I use a Ethernet switch from wago (industrial Ethernet switch) and I connect only one PC Ethernet port (the original one onboard port from ralteck), and the ethercat drive and c-mesa card to the same switch and was working fine, I did not spend to much time testing, because I need the machine back to work again,
I mean:  1 pc port, 1 Ethernet switch, 1 Ethercat drive (Z axis), 1 c-mesa card 7i92 with X, Y axis connected. runnig in a loop
o001;
g4 p2;
G0 x0 y0 x0;
g4 p2;
g0 x5 y5 z5;
m99
speed (90 ipm)
And I am really surprised that I test some mixed configuration and the CNC machine with probe basic GUI, and was working fine without prompt me a issue,
Last edit: 2 months 1 week ago by leexi.
2 months 1 week ago #348869 by NWE
Nice. Which model Wago ethernet switch did you use? I was under the impression most ethernet switches don't run ethercat.
2 months 1 week ago - 2 months 1 week ago #348964 by leexi
I use this one wago 852-111, I used on ethercat, as daisy chain device as ethercat topology concept (I mean on input one output), I do not test a star or other network topology, I use this to split the same PC NIC with, mesa card and internet connection, it is working fine all together, but I do not test like intensive mode for several hours.
The following user(s) said Thank You: NWE
Moderators: PCW, jmelson
Time to create page: 0.248 seconds
