7i95t firmware flash
1 month 1 week ago #349809 by geebee
Replied by geebee on topic 7i95t firmware flash
copy from terminal :
eebee@debian:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp8s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 9c:53:22:48:4a:55 brd ff:ff:ff:ff:ff:ff
altname enx9c5322484a55
inet 10.10.10.1/24 brd 10.10.10.255 scope global noprefixroute enp8s0
inet6 2003:ca:745:4b0:8af0:56c3:81dc:59d1/64 scope global dynamic noprefixroute
valid_lft 172796sec preferred_lft 86396sec
inet6 fe80::1f98:abff:6d07:69fe/64 scope link noprefixroute
3: eno1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
link/ether 50:46:5d:6f:50:7c brd ff:ff:ff:ff:ff:ff
altname enp0s25
altname enx50465d6f507c
4: wlp7s0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 6a:9d:f2:44:dc:7d brd ff:ff:ff:ff:ff:ff permaddr 64:70:02:18:5d:b8
altname wlx647002185db8
geebee@debian:~$
1 month 1 week ago #349810 by PCW
Replied by PCW on topic 7i95t firmware flash
OK so the next question is which Ethernet interface is the 7I95T connected to?
(enp8s0 or eno1)
(quick way to check is unplug the 7I95T RJ45 cable and see which interface shows "NO-CARRIER"
1 month 1 week ago #349811 by geebee
I just try to set the card to work.
For the beginning, I want it to get a single stepper motor to turn with nothing else connected to it. For this, I need to configure some hal and ini files. I can use mesact but not pncconf for this.Later, I will analyze and try to understand these first files according to linuxcnc docs. What i intend to do is retrofitting a lathe to cnc (two, maybe three axes) , an additional axe for an attached lathe and on for a dividing head and some encoders /DRO This is all I might need in the (far) future.
Right now, I would just be happy to get linuxcnc, mesact ,board and stepper (driver) "Talk to one another".
cheers
geebee
1 month 1 week ago #349813 by geebee
mesaboard is on 2. enp8s0 (see alsö static inet/inet6 addresses) It does show no carrier when unplugged.
eno1 (internet) has automatic connection method.
wlan has been turned off in order not to get confused.
I changed lan cables and now it behaves as it should mesact/machine finds the board and readhmid provides the information as expected.(mesact and terminal)
I wasnt aware of that since I did have acces to the internet anyhow(???).
so thank you very much for the moment This particular problem is solved.
Have nice days
geebee
Moderators: PCW, jmelson
