mesa 7i97T + 7i84U
3 weeks 5 days ago #350131 by angelnu
mesa 7i97T + 7i84U was created by angelnu
Hello.I have a cnc sharpener with motors and Italian analog servo drivers -10V Phase AX-V 06094. I want to upgrade to linuxcnc since the controller is an old PROMAX system that has an old SD card reader, it does not support modern sc cards. Some cards I have have errors and there are no spare parts. I think the phase drives are connected to SINCOS encoders, the driver has encoder outputs Ch A, Ch. B and Ch. C (Ch C seems to be index) the outputs are NPN open collector 30 V, 100 mA. Is it possible to connect these drivers to a 7i97T table card?, and also advice to expand the inputs since the 7i97T only has 16, I had thought about a 7i84U card.
Sorry if it's not right in English, my language is Spanish.
3 weeks 5 days ago #350132 by tommylight
Replied by tommylight on topic mesa 7i97T + 7i84U
I just wrote half a page and had to delete and start over:
-Use pins 14, 15, 16 on C2
-Set mesa for single ended encoders
-do not touch the wiring between drives and motors.
The following user(s) said Thank You: angelnu
3 weeks 5 days ago #350133 by PCW
Replied by PCW on topic mesa 7i97T + 7i84U
You can connect single ended NPN encoder outputs to the 7I97T
Worst case you might need a stiffer pullup resistor on the inputs
than the built in 2K ohm encoder input pullups on the 7I97T
A 7I84U (32 inputs 16 outputs)  or a 7I70 (48 inputs) can be used to expand the inputs on a 7I97T
3 weeks 4 days ago #350145 by angelnu
Replied by angelnu on topic mesa 7i97T + 7i84U
Thanks for responding.
Cables 14, 15 and 16 are used in the machine.
I wasn't planning to touch the cables between the driver and the encoder, they have 16 or 17 cables.
3 weeks 4 days ago #350146 by angelnu
It hasn't been clear to me about the resistors:
What value should the resistors have and what power should they dissipate?
4.7 ohm and 1/2 W resistors would be okay?
And I understand that they must be connected between the 5V pin of 7i97T and the QA, QB and IDX pins.
3 weeks 4 days ago #350147 by tommylight
They go back to the controller, you are swapping the controller, so they go to Mesa now.
Moderators: PCW, jmelson
Time to create page: 0.143 seconds
