Cannot use pins 2 - 9 as inputs, only outputs.
7 years 11 months ago #121703 by Emanresu
You never used a BOB but its 30 years ago since you made and wired your own one?
Doesnt matter...
I DONT use one. I run a MESA 6i25.
Now i wona combine my parport in "IN" mode
but pin 2-9 doesnt change.
7 years 10 months ago #121715 by Todd Zuercher
Which are you using a parallel port or a Mesa card?
7 years 10 months ago - 7 years 10 months ago #121716 by Emanresu
Both!
I use 3 axes + spindle + linear scales on a 7I85s.
Now i wona put a handwheel on my free parallel port.
Machine is a DIY with HSK63 Spindle.
So i also need more inputs for a toolchange.
Thats why i wona have it configured as "IN"
Last edit: 7 years 10 months ago by Emanresu.
7 years 10 months ago #121718 by Todd Zuercher
What if any daughter cards do you have for the 6i25? Maybe it would be better to attach your handwheel to that.
Perhaps you may need to add external pull up resistors to your inputs on the parallel port.
7 years 10 months ago - 7 years 10 months ago #121723 by jmelson
Emanresu wrote: Now i wona combine my parport in "IN" mode
What type of parallel port are you using? Plug-in card or on the motherboard?
If on motherboard, you may have to make a selection on the BIOS setup screen to enable
bidirectional (PS/2) mode.
If a plug-in card, it should do this, but some cards from the 1990's - 2000's needed to have a
setup utility run on them. Almost any plug-in card since 2000 should support this without any
special stuff.
And, finally, the parport driver in LinuxCNC needs a setting on the loadrt command line to
select bidir or input modes. If you specify that command wrong, it will default to output, and
you MAY NOT get any error message.
Jon
Last edit: 7 years 10 months ago by jmelson.
7 years 10 months ago #121873 by andypugh
Emanresu wrote: I use 3 axes + spindle + linear scales on a 7I85s.
TB1 pins 1 to 8 are a serial expansion port.
Plugging a 7i73 card in to that would give you 4 encoder / handwheel counters, drivers for a 64-key matrix-wired keypad, 8 inputs, 6 outputs and 8 analogue inputs. All for $50 and connected by a single CAT5 cable.
store.mesanet.com/index.php?route=produc...83_88&product_id=116
Moderators: PCW, jmelson
Time to create page: 0.220 seconds
