Re:Hardinge CHNC 1 Lathe
14 Apr 2010 12:56 - 14 Apr 2010 12:59 #2608
by BigJohnT
Replied by BigJohnT on topic Re:Hardinge CHNC 1 Lathe
Here is the code used
I wonder if there is a way to do this all in HAL and not with the ladder?
# Feed Override
net fob1 wsum.0.bit.0.in <= hm2_5i20.0.gpio.062.in_not
net fob2 wsum.0.bit.1.in <= hm2_5i20.0.gpio.060.in_not
net fob4 wsum.0.bit.2.in <= hm2_5i20.0.gpio.058.in_not
net fob8 wsum.0.bit.3.in <= hm2_5i20.0.gpio.056.in_not
net increase-for halui.feed-override.increase <= classicladder.0.out-05
net decrease-for halui.feed-override.decrease <= classicladder.0.out-06
setp mult2.1.in0 10
net current-for-int mult2.1.in1 <= halui.feed-override.value
net conv-FO conv-float-s32.0.in mult2.1.out
net req-feed-int classicladder.0.s32in-03 <= wsum.0.sum
net curr-feed-int classicladder.0.s32in-04 <= conv-float-s32.0.out
The ladder used.
Last edit: 14 Apr 2010 12:59 by BigJohnT.
15 Apr 2010 10:34 #2613
by Rick G
Replied by Rick G on topic Re:Hardinge CHNC 1 Lathe
Hello John,
Nice work. Also great that you have posted your project from crate to finish. When you first mentioned the switch I thought you would do it all with HAL. But if it ain't broken...
Rick G
Rick G
15 Apr 2010 10:39 #2614
by BigJohnT
Actually it is a bit slow and I'm going to replace the ladder with HAL comp when I get a few minutes to work on it.
15 Apr 2010 11:16 #2615
by Rick G
Hope you post that also when done. Have a great day.
Rick G
Rick G
15 May 2010 13:28 #2860
by BigJohnT
Here is a little video of the Hardinge making some seal washers for itself.
There is also one on what happens when you don't get your offsets correct...
- schmidtmotorworks
- Thank you received: 6
30 May 2014 20:18 #47548
by schmidtmotorworks
Replied by schmidtmotorworks on topic Hardinge CHNC 1 Lathe
John,
Thanks for your build thread.
It looks like you overcame a lot of challenges.
I happened to see a Hardinge CHNC Lathe on Craigslist and was wondering if you had it to do over if you would recontrol this machinr or look for something else?
orangecounty.craigslist.org/tls/4470722196.html
If any other LINUXCNC person is interested in it, go for it, I'm on the fence about it.
- Kirk_Wallace
- Thank you received: 7
30 May 2014 23:09 - 30 May 2014 23:10 #47558
by Kirk_Wallace
Replied by Kirk_Wallace on topic Hardinge CHNC 1 Lathe
Here is my version:
www.wallacecompany.com/cnc_lathe/HNC/
It was a pretty easy conversion, and now-a-days one can even reuse the resolvers. I believe Pico and Mesa have resolver adapters.
Last edit: 30 May 2014 23:10 by Kirk_Wallace. Reason: spelling error
30 Jul 2014 04:16 #49274
by jlviloria
Replied by jlviloria on topic Hardinge CHNC 1 Lathe
John greetings,
We have a hardinge like yours, we have only the spindle motor. there are no servo motors, servomotors driver or VFD spindle.
spindle motor is 5Hp, the first query that I have is whether I can adapt some VFD for this type of spindle.
besides that servomotors and drivers do you recommend for this machine,
there are no manuals of any kind.
From now appreciate any help you can give me, I have the reference at the time of the spindle motor. but I read in the forum that these machines come with the same spindle motor.
thanks,
Viloria
thanks,
Viloria
02 Oct 2023 16:46 - 03 Oct 2023 02:24 #282076
by Loren
Replied by Loren on topic Re:Hardinge CHNC 1 Lathe
Last edit: 03 Oct 2023 02:24 by Loren.
- Thank you received: 5918
02 Oct 2023 17:28 #282084
Replied by tommylight on topic Re:Hardinge CHNC 1 Lathe
@Loren,
Ask here as every normal person.
Remove your e-mail, please.
Moderators: cncbasher
Time to create page: 0.480 seconds
