- Thank you received: 6
You do not need a positioning servo to do rigid tapping.library wrote: I have a grizzly G0704 which is a popular conversion to cnc but most people use Mach. As a Linux systems administrator I prefer Linux.
I would like to add a position controlled spindle motor. The G0704 comes with a 1HP brushed DC motor. I would like something around 1.5-2kW (2-3HP) that can do rigid tapping and will spin at 5000 rpm
Well, you can get a variety of drives for brushless servo motors. Just because the motor sayslibrary wrote: I would like to use a brushless motor if possible due to the better performance and not dealing with brushes. The servo motors are just the right size. Tall and skinny. If I could drive a servo motor like a normal brushed motor I would be all over that in a heartbeat. If they sold a tall skinny brushless DC motor then I could power it easily with an e-bike controller and an old Dell Blade Chassis power supply.
Is there anything the motor would need to do for rigid tapping? Does it need to stop quickly? Start quickly? What's really needed other than a simple encoder. Do I need spindle speed control or linuxcnc just slaves the z axis to whatever rpms the motor is going at?
No, too rapid starting/stopping of the spindle will make it hard for the Z axis to follow!
