Hello, I´m drawing the servo motor & amplifier schematics, on the servo amplifier pin #13 is 5V, #14 is Limit Switch and it go to ground at the end of 14pin round conector (once connected to external box between CPU and ServodriveMotor Assy), pin #15 is 0V (GRD) or 5V return, pin #16 is PWM, pin #17 is NPWM and pin #17 is shield and chassis earth/ground.
I would like if you repeat the test with scope of PWM using pin #15 as ground, Ch1 on PWM and Ch2 on NPWM.
5 Vdc supply comes from Motherboard´s servoboard on console and generally it returns (0V) is connected to chassis earth/ground, it is connected to the servo motor encoder (HEDS-9000 Avago) and 2 optocouplers in servo amplifier main pcboard.
Limit switch activates an optocoupler 6N139 (single LED input Darlington output) and PWM /NPWM activates HCPL2232 (2 LED input each outs to AND gate).
I have Mesa board and I´m trying to connect this drive to upgrade the proprietary 486 motherboard´s console.
