MC 500V Minimaster retrofit
10 years 9 months ago #69103 by Ldguinn1
Ok for today, trying to be as systematic as possible. Hooked up encoders, supplied 12v as required, I get an index pulse = true but thats all. On my 7i77 my cr15 LED is solid green, while cr16 is solid red. never changes. Does this mean some sort of communication failure? Just trying to get some of the encoder stuff working before I hook motor power up. I can see all the pins, just cant get any info to them, or it seems from them. :unsure:
Lyle
10 years 9 months ago #69107 by BigJohnT
A 7i77 when powered up and happy will have 4 yellow leds. CR15 Green Lower right Field I/O activity CR16 Red Lower right Field I/O fault. In normal operation CR1 through CR7 must always be on. At power-up, CR15 should be off and CR16 on. The red LED CR16 indicates a watchdog fault, which is expected before host communications are established. Once running, CR15 should blink at about 1 Hz for a 1 KHz update rate, and CR16 should be off. Note: CR15 and CR16 are only present in revision B or greater 7I77 cards.
JT
10 years 9 months ago #69109 by Ldguinn1
Yeah the red never goes off. And the green never blinks. So maybe the cable could be bad?
10 years 9 months ago - 10 years 9 months ago #69120 by PCW
Replied by PCW on topic MC 500V Minimaster retrofit
Sounds like the 7I77 is jumpered for setup rather than operate mode
did you change any jumpers?
W4 and W12 must be set for operate mode (Left position) for normal operation
Last edit: 10 years 9 months ago by PCW.
10 years 9 months ago #69129 by Ldguinn1
thank you it was jumpered for setup. resolved that, I get all the yellow leds lit, but the cr15 is out and cr16 (watchdog?) solid red.
Linuxcnc ver 2.7.3 while reading posts last night maybe need to revert to older version?
10 years 9 months ago #69131 by PCW
Thats the expected LED display when LinuxCNC is not running or perhaps not setup correctly
Time to create page: 0.212 seconds
