retro a anilam crusader II on a alliant mill
10 years 10 months ago - 10 years 10 months ago #67361 by jamby
Howdy
I have had a Alliant (bridgeport clone) knee mill for over 10 years. Its a good steady runner, one glass scale and a blown resistor in that time. The Anilam Crusader II works well but I am getting tired of uploading files as the controller will only take about 28k of data at a time.
What is the minimum retro that I could do to it to get increased file sizes. I'd rather not gut it as everything is working now. I am use to Centos linux so I can deal with linuxcnc (maybe) and I ran ubuntu a few times. Is it possible to replace just parts of the control with linuxcnc??
Westamp boards, SEM servos, glass scales and ball screws. I looked at this 4 or 5 years ago and everyone wanted to go to stepper motors... No.
Jim
Last edit: 10 years 10 months ago by jamby.
10 years 10 months ago - 10 years 10 months ago #67363 by kornphlake79
Replied by kornphlake79 on topic retro a anilam crusader II on a alliant mill
Minimum hardware is:
1) a PC with LinuxCNC
2) some kind hardware to send a signal to your servo drives and receive a signal from the encoders. Pico and Mesa are the most popular
3) some cables, although you might be able to reuse your existing cables depending on what connectors they have.
4) plenty of grey stuff between your ears
Last edit: 10 years 10 months ago by kornphlake79.
10 years 10 months ago #67364 by jamby
kornphlake79
Thanks Kornphlake. Gray matter is rare this time of night.
Would like to replace the control box on the raised post and make connections to a computer with drive cards. Leaving the box with the amps and transformers alone.
Jim
10 years 10 months ago #67507 by andypugh
Replied by andypugh on topic retro a anilam crusader II on a alliant mill
jamby wrote: I looked at this 4 or 5 years ago and everyone wanted to go to stepper motors... No.
Was that here, or Mach3?
It should be a simple conversion, you basically just need to read the scales and send velocity commands to the drives. Let the drives and tachometers handle the velocity feedback loop.
Options include
Pico: www.pico-systems.com/PPMC.html
Mesa: store.mesanet.com/index.php?route=produc...83_84&product_id=214
General Mechatronics: www.generalmechatronics.com/en/linuxcnc
Then there are the older, less supported systems such as the Servo-to-Go and Motenc card that LinuxCNC first worked with:
wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_Supported_Hardware
10 years 10 months ago - 10 years 10 months ago #67522 by jamby
Andy
Probably other sites, definitely not here. As I remember it, few people had a board to handle servos, everything was steppers. Or at least an affordable option.
I have been reading posts here about the mesa boards and that looks like the way I'll go but I am not sure how to accomplish what I want. I was hoping someone who has already done this conversion could help me out with how they did it and how the finished unit looks and works. At least one person has done this conversion on a Crusader M series but I am not sure what the differences are.
If the old controller box has 5 connectors. Power, Xaxis, Yaxis, Zaxis, and a large plug with the wiring from the main box containing the servo amps. Can it be replaced by a PC with the mesa boards and a monitor? Since the old control has a E-stop and reset button can those be wired in separately?
With the mesa boards as in the Kit you showed, are there cards required for each drive or will those two cards handle all drives. And possibly a fourth axis?
Jim
10 years 10 months ago #67528 by 5axisormore
Replied by 5axisormore on topic retro a anilam crusader II on a alliant mill
I have the 6i25 and 7i77 board that I am going to use for my Anilam Crusader II with linear scales. I am purchasing the ENCY encoder splitters as well, so I can use the original control in manual mode as a DRO while tuning the Linux CNC. I went with the 6i25 which is PCIe. It works the same as 5i25 PCI board, but is the later slot type. Mine are Glentec drives, and if you do a bit of searching, you can find wiring diagrams for most of the info you need on your control. Mine was pre-RS232, so that was my main reason for changing.I have also considered AMC 30a8 brush type drives from Ebay if the originals fail. do a search and you should find several others have done this conversion already.
Fred
Time to create page: 1.593 seconds
