Old mouse instead of encoder
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Apr 2016 09:32 #72689 by aleksamc
Old mouse instead of encoder was created by aleksamc
I don't have encoders on my CNC machine.
Is it possible to connect encoders programmatically of old mouse to LPT port.
04 Apr 2016 12:58 #72711 by andypugh
Replied by andypugh on topic Old mouse instead of encoder
You can't do it programmatically. You will need wires.
Once physically connected it should be possibly to use the quadrature signals in HAL.
  • aleksamc
  • Platinum Member
  • Platinum Member
05 Apr 2016 10:02 #72772 by aleksamc
Replied by aleksamc on topic Old mouse instead of encoder
If I'll connect them in in HAL by net function, how I should tell linuxcnc - that it's encoder's input? Or I need somehow to calculate speed of motor and tell it to linuxCNC?
05 Apr 2016 10:10 #72773 by andypugh
You need to wire the quadrature signals into a HAL encoder module
linuxcnc.org/docs/2.7/html/man/man9/encoder.9.html
  • aleksamc
  • Platinum Member
  • Platinum Member
05 Apr 2016 20:45 #72810 by aleksamc
I will wire signal of parport to encode but what next?
How to wire position ot axis?
In main hal-file there is lines:
zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
zpos-fb stepgen.2.position-fb =>axis.2.motor-pos-fb
zstep <=stepgen.2.step
zdir <= stepgen.2.dir
I suppose I must somehow change zpos? And to write it incustom.hal.
If I'll connect such encoder, will this loop be closed ot I need to set PID-regulator for it?
05 Apr 2016 22:06 #72814 by andypugh
Can you explain what you are trying to do?
Just adding an encoder to a stepper system doesn't gain you very much. What do you propose to do if the stepgen and encoder disagree about where the axis is? It isn't like you can turn up the motor torque to recover the error.
  • aleksamc
  • Platinum Member
  • Platinum Member
06 Apr 2016 05:31 #72823 by aleksamc
I want to add feedback for one axis Z through parallel port. If I will connect it successfully and it will work and compensate error of losing steps, I will by hardware for encoder end encoders for all 3 axis.
Now I already have openloop step motors that works very slowly. I don't want to buy expensive drivers with feedback instead of mine but make feedback through linuxCNC. I'm new in linuxCNC. Now I study documentation. On the first pages of guick start manual It was written that linuxCNC can serv feedback of motors.
06 Apr 2016 09:10 #72827 by andypugh
All you can really do with encoder feedback on a stepper motor is detect loss of steps and stop the machine with an error.
Steppers make peak torque at low step rates. A closed loop system can only increase step rate after a missed step, which will lower the torque, making a lost step _more_ likely.
Unless you have a way to increase the drive _current_ on the basis of measured position error the encoder will not help in your situation.
  • aleksamc
  • Platinum Member
  • Platinum Member
06 Apr 2016 09:31 #72830 by aleksamc
And what should I do in this situation?
Can driver for stepper motor change this situation?
It would be nice that linuxCNC sends impulses till position of motor not get's to check point. I supposed it works like this when encoder is connected.
06 Apr 2016 09:42 #72832 by andypugh
It is very unlikely to work, but feel free to try.
Time to create page: 0.146 seconds
