Looking for the pinouts for this glass scale: Heindehain AE LS 106C
8 years 6 months ago #108419 by Bari
imagebin.ca/v/3xI71akm3mVL
imagebin.ca/v/3xI7HpLPmBLD
If I can find power and GND I can find the rest, but looking for any docs if you have them.
8 years 6 months ago #109833 by Bari
The diagram is only good if you have the matching cables since they only have the pinouts listed for the one end of the cable. It lists the signals for the pins in the connector that plugs into the display, not the connector that plugs into the read head of the encoder. Looks like Heindehain doesn't want to help you if you don't have their matching cables.
I did find the matching cables and using the above pinout in the doc find what I was looking for.
Thanks again for looking!
8 years 6 months ago - 8 years 6 months ago #109843 by kornphlake79
I have some experience with Heidenhain lc181 and lc183 glass scales. Support in the US is very poor, the engineers in Germany don’t communicate with international entities.
The LC181/183 scales use ENDAT, as I understand it is a protocol instead of a quadrature or analog signal. You would need an ENDAT capable device to interpret the signal to use them. Rexroth Indramat drives are able to natively interpret ENDAT encoders, but like Heidenhain, Rexroth support is poor in the US.
Last edit: 8 years 6 months ago by kornphlake79.
8 years 6 months ago #109844 by Bari
The LC-106C has the 11-μAPP interface.
I'm actually a few minutes away from the Rexroth HQ in the USA if I needed anything.
Time to create page: 0.184 seconds
