Fanuc servo drivers with fiber optic
8 years 2 months ago - 8 years 2 months ago #115821 by dm17ry
hm. the cheapest toslink cable connectors fit fine into hitachi transceivers without any grinding. and i'm surprised about attenuation.. mitsubishi drives work even without properly seating the connector - it is enough to shine a light from the end of the fiber into the hole from a few millimeters away.
i doubt an active splitter will work - i think it is electronic and doesn't have enough bandwidth.
what kind of cables and splitter you've got? have a picture?
the wavelength. i've seen pictures of some random fanuc stuff using TODX283 and DC9325. both are 650nm and 50Mbps. unless they have multiple incompatible standards - good chance that TODX2910 is the same...
Last edit: 8 years 2 months ago by dm17ry.
8 years 2 months ago #115824 by lkavan
This Fanuc FSSB uses probably optical connectors JIS F07 (duplex) it was necessary to grind plastic part of connectors a bit, metal insert with the fibre match OK. I used these cables:
www.krup.cz/default.asp?cls=stoitem&stiid=927
Cables was OK, machine works with these cables.
I also bought this passive splitter and it doesn't work, it has really too high loss:
www.krup.cz/default.asp?cls=stoitem&stiid=5145
Now I want toorder this active splitter:
www.krup.cz/default.asp?cls=stoitem&stiid=5749
I hope there will be toslink optical receiver connected with two transmitters - and then should be possible to sniff the data here ;-)
When I will open machine next time, I will take some photos.
BTW: Fanuc PCI card at your picture looks interesting.What is it? Maybe, is it possible to use it?
8 years 2 months ago - 8 years 2 months ago #115825 by dm17ry
probably your cables should fit if you cut off the molded PVC connector shell with the strain relief...
toslink receivers/transmitters are rated to 15Mbps - i doubt you will sniff anything with them.
fanuc pci card - no idea that it is, i just googled for "fanuc pcb" images
passive splitter which worked for me looks like this: www.nej-ceny.cz/647295/2portovy-digitaln...cerny-vlasp2502.html
8 years 2 months ago - 8 years 2 months ago #116217 by lkavan
Hallo, I have new informations. I ordered passive splitter like at your picture, but is it similar like I had before, Fanuc doesn't work with it. I think, optical power is divided half and half to each outputs and 50% is not enough for receiver, I think. I also ordered active splitter, but as we estimated, it doesn't work at all. There are some SMD ICs inside (amplifiers? Schmitt triggers?) but all signal ways are capacitor-coupled, so it will be frequency sensitive. I think it is the time to order 50Mb receiver and transmitter and make my own "sniffing amplifier"
Last edit: 8 years 2 months ago by lkavan.
8 years 2 months ago - 8 years 2 months ago #116231 by dm17ry
huh! looks like fanucs make somewhat picky hardware... :)
FYI, mitsubishi drives re-clock the signal when passing it down the chain, it's not just direct receiver-transmitter connection...
btw, you probably can plug into the last amp output to at least have a look at the controller commands...
6 years 4 weeks ago #184672 by Hamada
dm17ry wrote: packets are XOR'd with a pseudo-random sequence and then transmitted using a slightly modified 8b/10b encoding.
yurtaev.com/yssc3p.html
Can you help to supply more info for this?
1. Packets was encoded 8B/10B before or after scrambling (XOR'd with a pseudo-random sequence) ?
2. What is scrambler polynomial? p(x)= x7 + x4 + 1?
Time to create page: 0.063 seconds
