- Hardware & Machines
- CNC Machines
- Yaskawa SGDB to 7i77 - drives don't have the 'standard ' 50 pin connectors
- SPH
- Thank you received: 6
19 Sep 2019 12:12 - 19 Sep 2019 12:13 #145578
by SPH
Yaskawa SGDB to 7i77 - drives don't have the 'standard ' 50 pin connectors was created by SPH
I've got my Mesa hardware finally and can now look into getting everything wired up.
The manual for these drives is massive and surprisingly often lacking in actual useful info.
In this case the whole manual constantly refers to the 50 pin 1CN connector. Well mine don't have a 50 pin 1CN, they've got 26 pin 1CN's and a 9 pin 4CN. 4CN is referred to once in 500 pages and it's to describe the connector number and manufacturer. Sweet.
In its original setup the 4CN connectors on all 4 drives were daisy chained together with a cable that terminated at the HSD motion controller.
The 26 pin 1CN looks to have the enable, ready, limit and home switches connected to it.
My issue is I have no idea how to get the encoder signals to the 7i77 as I don't have a pinout to refer to that actually relates to these drives.
Any one seen this before?
Last edit: 19 Sep 2019 12:13 by SPH.
- bevins
- Thank you received: 338
19 Sep 2019 12:25 - 19 Sep 2019 12:27 #145579
by bevins
Whats the drive full model#? Show a pic of the drive also.
SGDB drives have encoder outputs that connect right into the 7i77.
They also have velocity +-10 control that also connects to the 7i77.
Replied by bevins on topic Yaskawa SGDB to 7i77 - drives don't have the 'standard ' 50 pin connectors
Last edit: 19 Sep 2019 12:27 by bevins.
- SPH
19 Sep 2019 12:36 - 19 Sep 2019 12:39 #145583
by SPH
Replied by SPH on topic Yaskawa SGDB to 7i77 - drives don't have the 'standard ' 50 pin connectors
Good point, sorry for not providing full info.
Drives are SGDB-02VN, 10VN, 15VN and 20VN
I don't have a picture that I can upload quickly but here's a pic of a drive that looks exactly the same as mine. Looks like all the VN series have the same connector configuration.
*sorry, pic link was a dud, a quick search of SGDB-02VN will bring up a few pics of the same drives with the 9 pin 4CN connector visible top left.
Last edit: 19 Sep 2019 12:39 by SPH.
- Thank you received: 5332
19 Sep 2019 13:01 - 19 Sep 2019 13:01 #145584
Replied by PCW on topic Yaskawa SGDB to 7i77 - drives don't have the 'standard ' 50 pin connectors
Unfortunately I'm pretty sure the SGDB-XXXN drives are Mechatrolink interfaced drives
not analog/step-dir like SGDB-XXAD drives
Take a look at this thread:
www.forum.linuxcnc.org/27-driver-boards/...trolink-ii-interface
Not sure if dm17try has an interface or not but he would be the one to ask
Last edit: 19 Sep 2019 13:01 by PCW.
- bevins
19 Sep 2019 15:38 #145593
by bevins
You have a reference for these servopacks?
Do you know if SGDB-XXVD-Y1 is capable of analog control?
19 Sep 2019 17:42 #145605
I dont know off hand, you can find a pdf for some mechatrolink drives by googling for "SGDB-ON"
The following user(s) said Thank You: bevins
- bevins
19 Sep 2019 18:30 #145610
by bevins
Thanks, I found the suffix list for SGDB
- SPH
19 Sep 2019 21:53 #145632
by SPH
This is a bit of a set back to be honest. Classic example of not knowing what I don't know.
My level of knowledge isn't really up to blazing new trails with this gear, I might have to look for new drives (or newer at least).
I guess I can always ebay up some more standard sigma 1 or 2 drives and sell mine. Might be cheaper to get DMM though.
Let me know what you guys think, is it easier to just look for newer sigma drives? Can I keep my motors?
- SPH
20 Sep 2019 00:51 #145641
by SPH
I’m here at the workshop looking over the machine. Doing a bit of eBay trawling while I’m at it. There are quite a few sgdb drives available from China at around $500 each. The main one I’d be concerned with is the x axis as it’s a 1.8kw motor and replacing it would be a major headache. Just because it’s so hard to access, adapting a new motor in there would be horrible. Also a new 1.8kw motor and drive would be prohibitively expensive.
I could easily adapt the y and z motors to newer, smaller servos. The z no longer needs to be the 1.5kw monster is was when it had the boring head and 100kgs of shrouding installed. A 1kw would be heaps. Same for the y axis. It’s 0.85kw now, could be less but I’d probably just order two 1kw or the same kind.
Any thoughts? Would I have any potential problems running two different brands of motor and drive on the different axis’?
My main thought with replacing the drives and motors all together is I can hopefully get around some of the issues I see people having getting these things tuned and running correctly. I’d only have the one 20 year old drive to tackle.
- bevins
20 Sep 2019 01:13 - 20 Sep 2019 01:19 #145642
by bevins
Its not that bad......
China - 1.8kw AC servo and drive
China 1kw AC servo and drive
Here are same ac servos on a cnc router I did with a friend. But are 1.2kw X, 2-Y with planetary gearboxes and .750kw on Z axis.
Been working for years now, not one issue.
Last edit: 20 Sep 2019 01:19 by bevins.
The following user(s) said Thank You: SPH
- CNC Machines
Time to create page: 0.134 seconds
